[petsc-users] help about my ts program
    Xuan YU
    xxy113 at psu.edu
    Fri Jul  2 13:08:14 CDT 2010
On Jun 23, 2010, at 10:44 AM, Jed Brown wrote:
> On Wed, 23 Jun 2010 10:22:19 -0400, Xuan YU <xxy113 at psu.edu> wrote:
>> I got the correct results! Thanks!
>> Could you please tell me whether I can use TS to solve ODE without
>> providing Jacobian matrix?
> Sure, use -snes_mf to solve it without assembling any matrix (linear
> systems are solved with an unpreconditioned Krylov method).  Note that
> this usually will not converge for larger problems.  To assemble a
> dense
> matrix by finite differencing, you can use -snes_fd.
If I don't provide Jacobian, it will be:  type: euler
                   						  total number of nonlinear solver iterations=0
								  total number of linear solver iterations=0
> To use coloring to compute a sparse matrix efficiently, you have to
> know
> the sparsity pattern of the Jacobian, try something like (this is
> somewhat different in petsc-dev than release).
>    ISColoring     iscoloring;
>    ierr = DAGetColoring(rd-
> >da,IS_COLORING_GLOBAL,MATAIJ,&iscoloring);CHKERRQ(ierr);
>    ierr =
> MatFDColoringCreate(B,iscoloring,&matfdcoloring);CHKERRQ(ierr);
>    ierr = ISColoringDestroy(iscoloring);CHKERRQ(ierr);
>    ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode(*)
> (void))SNESTSFormFunction,ts);CHKERRQ(ierr);
>    ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr);
>    ierr =
> SNESSetJacobian
> (snes
> ,A,B,SNESDefaultComputeJacobianColor,matfdcoloring);CHKERRQ(ierr);
> Jed
Now I added coloring
         ierr = TSCreate(PETSC_COMM_WORLD,&ts);CHKERRQ(ierr);
         ierr = TSSetProblemType(ts,TS_NONLINEAR);CHKERRQ(ierr);
         ierr =
TSMonitorSet(ts,Monitor,&appctx,PETSC_NULL);CHKERRQ(ierr);
         ierr = TSSetSolution(ts,CV_Y);CHKERRQ(ierr);
         ierr = TSSetRHSFunction(ts,f,&appctx);CHKERRQ(ierr);
    ierr=DACreate2d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_STAR,
1,1,PETSC_DECIDE,PETSC_DECIDE,
                     1,1,PETSC_NULL,PETSC_NULL,&da);CHKERRQ(ierr);
         DACreateGlobalVector(da,&CV_Y);
         ierr =
DAGetColoring(da,IS_COLORING_GLOBAL,MATAIJ,&iscoloring);CHKERRQ(ierr);
         DAGetMatrix(da,MATAIJ,&J);
         MatFDColoringCreate(J,iscoloring,&matfdcoloring);
(*)(void))f,da);CHKERRQ(ierr);
TSSetRHSJacobian(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);
         ierr = TSSetType(ts,TSPSEUDO);CHKERRQ(ierr);
         ierr = TSSetInitialTimeStep(ts,0,1.0);CHKERRQ(ierr);
         ierr =
TSSetDuration(ts,cData.EndTime,cData.EndTime);CHKERRQ(ierr);
         ierr = TSSetFromOptions(ts);CHKERRQ(ierr);
         ierr = TSSetUp(ts);CHKERRQ(ierr);
         ierr = TSStep(ts,&its,&ftime);CHKERRQ(ierr);
When I run the code, I got the following:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: User provided compute function generated a Not-a-Number!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 2, Fri Apr 30
20:23:44 CDT 2010
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./pihm on a linux-gnu named lionxi.rcc.psu.edu by
xxy113 Fri Jul  2 13:53:44 2010
[0]PETSC ERROR: Libraries linked from /gpfs/home/xxy113/soft/petsc-3.1-
p2/linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Tue May 11 13:53:58 2010
[0]PETSC ERROR: Configure options --with-cc=gcc --download-f-blas-
lapack=1 --download-mpich=1
[0]PETSC ERROR:
[0]PETSC ERROR: SNESSolve_LS() line 168 in src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 2255 in src/snes/interface/snes.c
[0]PETSC ERROR: TSStep_Pseudo() line 163 in src/ts/impls/pseudo/
posindep.c
[0]PETSC ERROR: TSStep() line 1693 in src/ts/interface/ts.c
[0]PETSC ERROR: User provided function() line 216 in /work/petsc/
pihm.c(which is ierr = TSStep(ts,&its,&ftime);CHKERRQ(ierr);)
Could you please tell me how to check where is my problem?
Xuan YU
xxy113 at psu.edu
