[petsc-users] where is PCREDISTRIBUTE?
Christian May cmay at phys.ethz.ch
Sun Jan 31 07:10:09 CST 2010
Thanks, Matt. The preconditioner is now available, but when I invoke it
with
-ksp_type preonly -pc_type redistribute -redistribute_ksp_type cg
-redistribute_pc_type bjacobi -redistribute_sub_pc_type icc
I get the following error:
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 5!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
cec5db6729c23bbdb9cc80092ac1dc4ccc7e9069 HG Date: Fri Jan 29 22:04:34 2010 -0600
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./SPsolver2D-petsc on a linux-gnu named
a6256.hpc-net.ethz.ch by cmay Sun Jan 31 11:10:52 2010
[0]PETSC ERROR: Libraries linked from /cluster/work/phys/cmay/petsc/lib
[0]PETSC ERROR: Configure run at Sat Jan 30 11:48:43 2010
[0]PETSC ERROR: Configure options --prefix=/cluster/work/phys/cmay/petsc/ --with-c++-support --with-precision=double --with-sha
red=0 --download-superlu_dist=1 --with-superlu_dist --with-parmetis-lib="[/cluster/work/phys/cmay/petsc/petsc-3.0.0-p3/external
packages/ParMetis-3.1.1/libparmetis.a,/cluster/work/phys/cmay/petsc/petsc-3.0.0-p3/externalpackages/ParMetis-3.1.1/libmetis.a]"
  --with-parmetis-include=/cluster/work/phys/cmay/petsc/petsc-3.0.0-p3/externalpackages/ParMetis-3.1.1/ --with-x=0 --with-mpi-di
r=/cluster/apps/openmpi/1.2.7/x86_64/intel/ --with-fc=0
--download-c-blas-lapack=yes
[0]PETSC ERROR:
[0]PETSC ERROR: MatGetSubMatrix() line 6519 in src/mat/interface/matrix.c
Thanks
Christian
>Yes, you will need petsc-dev. Note that we will release 3.1 in just a few
>weeks.
>  Thanks,
>     Matt
>On Sat, Jan 30, 2010 at 4:57 AM, Christian May <cmay at phys.ethz.ch>
wrote:
>> Hi everybody,
>> I want to use the redistribute preconditioner to keep a matrix
symmetric as
>> explained in the FAQ. However, the source is not contained in my
up-to-date
>> installation of petsc-3.0.0-p10. Is this intended?
>> Do I have to install the development version or how can I obtain this
>> additional preconditioner?
>> Thanks
>> Christian
