[petsc-users] Question about matrix permutation
Jed Brown
jed at 59A2.org
Sat Jan 30 13:38:04 CST 2010
On Fri, 29 Jan 2010 16:52:51 -0600, Barry Smith <bsmith at mcs.anl.gov> wrote:
> It is possible some times to "turn hardware prefetching off",
> possibly with Intel compiler options.
Hmm, I had never heard of this. Apparently the instruction can only be
executed in ring 0, and though the Linux kernel exposes this.
resulting thing.
http://stackoverflow.com/questions/784041/how-do-i-programatically-disable-hardware-prefetching
Anyway, I didn't bother with this.
> I owe you a beer if the difference is more than say 2 percent.
Would you accept a 30 percent speedup instead of a 2 percent slowdown?
Apply the attached patch, compile with GCC (I don't know if other
compilers have the same __builtin_prefetch), and compare the following
(top result is before the patch).
./ex19 -ksp_type cgs -pc_type none -ksp_monitor -ksp_max_it 1000 -snes_max_it 1 -da_grid_x 50 -da_grid_y 50 -log_summary
MatMult 2001 1.0 5.3909e+00 1.0 3.03e+09 1.0 0.0e+00 0.0e+00 0.0e+00 41 41 0 0 0 82 81 0 0 0 563
MatMult 2001 1.0 3.9953e+00 1.0 3.03e+09 1.0 0.0e+00 0.0e+00 0.0e+00 38 41 0 0 0 77 81 0 0 0 759
./ex19 -ksp_type cgs -pc_type none -ksp_monitor -ksp_max_it 100 -snes_max_it 1 -da_grid_x 200 -da_grid_y 200 -log_summary
MatMult 201 1.0 7.9618e+00 1.0 4.98e+09 1.0 0.0e+00 0.0e+00 0.0e+00 28 38 0 0 0 60 77 0 0 0 626
MatMult 201 1.0 6.1575e+00 1.0 4.98e+09 1.0 0.0e+00 0.0e+00 0.0e+00 24 38 0 0 0 54 77 0 0 0 809
./ex19 -ksp_type cgs -pc_type none -ksp_monitor -ksp_max_it 100 -snes_max_it 1 -da_grid_x 300 -da_grid_y 300 -log_summary
MatMult 201 1.0 1.7829e+01 1.0 1.12e+10 1.0 0.0e+00 0.0e+00 0.0e+00 27 38 0 0 0 60 77 0 0 0 630
MatMult 201 1.0 1.3561e+01 1.0 1.12e+10 1.0 0.0e+00 0.0e+00 0.0e+00 24 38 0 0 0 53 77 0 0 0 828
This blows me away.
Jed
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100130/8564b0bf/attachment.bin>
