[petsc-users] valgrind errors.
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Tue Jan 19 12:49:36 CST 2010
Dear Barry,
I switched from using temp arrays via PetscMalloc() and PetscFree() to
creating a DA and using DAGetLocalVector()+DAVecGetArray() to get
fieldother as a temp array.
However, I do not think DAGetLocalVector()+DAVecGetArray() is a must
in my case, I tried DAGetArray() to take over of the above two.
However, I have the error message saying
twgcqt2unff.c:2150: warning: passing argument 3 of ?DAGetArray? from
incompatible pointer type
twgcqt2unff.c:3213: warning: passing argument 3 of ?DARestoreArray?
from incompatible pointer type
The code looks like:
typedef struct {
PetscReal x1,x2,x3,x4;
} FieldOther;
#undef __FUNCT__
#define __FUNCT__ "FormFunction"
PetscErrorCode FormFunction(SNES snes,Vec X,Vec F,void*dummg)
DA dafieldother;
FieldOther **fieldother;
Vec FIELDOTHER;
PetscFunctionBegin;
ierr = DAGetLocalInfo((DA)dmmg->dm,&info);CHKERRQ(ierr);
ierr = DACreate2d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_BOX,
info.mx, info.my, PETSC_DECIDE, PETSC_DECIDE, 4, 2, 0, 0,
&dafieldother);CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 0, "x1");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 1, "x2");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 2, "x3");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 3, "x4");CHKERRQ(ierr);
// ierr = DAGetLocalVector(dafieldother,&FIELDOTHER);CHKERRQ(ierr);
// ierr = DAVecGetArray(dafieldother,FIELDOTHER,&fieldother);CHKERRQ(ierr);
ierr = DAGetArray(dafieldother,PETSC_TRUTH,&fieldother);CHKERRQ(ierr);
for (j = jFirst; j <= jLast; j++){
for (i = iFirst; i <= iLast; i++){
fieldother[j][i].x1 = 0;
fieldother[j][i].x2 = 0;
fieldother[j][i].x3 = 0;
fieldother[j][i].x4 = 0;
ffield[j][i].x1 = fieldother[j][i].x1;
// ierr =
DAVecRestoreArray(dafieldother,FIELDOTHER,&fieldother);CHKERRQ(ierr);
// ierr = DARestoreLocalVector(dafieldother,&FIELDOTHER);CHKERRQ(ierr);
ierr = DARestoreArray(dafieldother,PETSC_TRUTH,&fieldother);CHKERRQ(ierr);
ierr = DADestroy(dafieldother);CHKERRQ(ierr);
PetscFunctionReturn(0);
What could be wrong with it?
Thanks very much!
Rebecca
Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> err =
>> PetscMalloc(sizeof(PetscReal)*(info.mx)*(info.my)*sizeof(FieldOther),
> This line is wrong, but is not the cause of the problem.
> sizeof(FieldOther) takes into account the size of the real values
> inside so you do not need the sizeof(PetscReal)*
> What are iFirst and iLast? If they are not 0 then you indexing into
> fieldother[] wrong since that array starts at 0.
> Barry
> On Jan 19, 2010, at 11:24 AM, (Rebecca) Xuefei YUAN wrote:
>> Dear Jed,
>> I found the source of these uninitialised values.
>> In my FormFunction(), there is a user-defined structure called
>> FieldOther and I will use this as a temp values to build up my
>> residual function. The main loop is like:
>> typedef struct {
>> } FieldOther;
>> #undef __FUNCT__
>> FieldOther *fieldother;
>> PetscFunctionBegin;
>> ierr =
>> fieldother[(i)+(j)*(info.mx)].x1 = 0;
>> fieldother[(i)+(j)*(info.mx)].x2 = 0;
>> fieldother[(i)+(j)*(info.mx)].x3 = 0;
>> fieldother[(i)+(j)*(info.mx)].x4 = 0;
>> // errors coming out from valgrind if fieldother[] is used in
>> residual function evaluation.
>> // ffield[j][i].x1 = fieldother[(i)+(j)*(info.mx)].x1;
>> // everything looks fine from valgrind if fieldother[] is not used
>> in residual function evaluation.
>> ffield[j][i].x1 = field[j][i].x1;
>> ierr = PetscFree(fieldother);CHKERRQ(ierr);
>> If I will use those fieldother[] in my residual evaluation
>> functions, errors from valgrind come out like:
>> ==24486==
>> ==24486== Conditional jump or move depends on uninitialised value(s)
>> ==24486== at 0x4024D9B: memcpy (mc_replace_strmem.c:482)
>> ==24486== by 0x41F6387: __printf_fp (in /lib/tls/i686/cmov/libc-2.7.so)
>> ==24486== by 0x41F1563: vfprintf (in /lib/tls/i686/cmov/libc-2.7.so)
>> ==24486== by 0x41F5581: ??? (in /lib/tls/i686/cmov/libc-2.7.so)
>> ==24486== by 0x41F1229: vfprintf (in /lib/tls/i686/cmov/libc-2.7.so)
>> ==24486== by 0x8643996: PetscVFPrintfDefault (mprint.c:193)
>> ==24486== by 0x85F3F00: PetscViewerASCIIMonitorPrintf (filev.c:988)
>> ==24486== by 0x80C814A: SNESMonitorDefault (snesut.c:150)
>> ==24486== by 0x80E0450: SNESSolve_LS (ls.c:173)
>> ==24486== by 0x80C199F: SNESSolve (snes.c:2221)
>> ==24486== by 0x80DA4A0: DMMGSolveSNES (damgsnes.c:510)
>> ==24486== by 0x80D3CDF: DMMGSolve (damg.c:372)
>> ==24486== Uninitialised value was created by a heap allocation
>> ==24486== at 0x4022BF3: malloc (vg_replace_malloc.c:195)
>> ==24486== by 0x864BAFC: PetscMallocAlign (mal.c:40)
>> ==24486== by 0x864CBEB: PetscTrMallocDefault (mtr.c:194)
>> ==24486== by 0x8055FB8: FormFunction (twgcqt2unff.c:941)
>> ==24486== by 0x80B86A4: SNESComputeFunction (snes.c:1016)
>> ==24486== by 0x80DFFC2: SNESSolve_LS (ls.c:159)
>> ==24486== by 0x804F539: Solve (twgcqt2unff.c:437)
>> ==24486== by 0x804DC92: main (twgcqt2unff.c:283)
>> FormFunction (twgcqt2unff.c:941) is located at the line of
>> ierr =
>> I think I did give values of those fieldother and free them after
>> usage, but why this uninitialised message comes out all the time?
>> Thanks very much!
>> Rebecca
>> Quoting Jed Brown <jed at 59A2.org>:
>>> On Mon, 18 Jan 2010 16:32:22 -0500, "(Rebecca) Xuefei YUAN"
>>> <xy2102 at columbia.edu> wrote:
>>>> Dear Jed,
>>>> I got some origins, but I still do not understand what is going on here?
>>>> Here is a piece of uninitialised value from
>>> I think you have an indexing error while reading from this local vector
>>> in your residual evaluation. The contents of the array are explicitly
>>> initialized to zero in VecCreate_Seq, but when memalign is not available
>>> (your trace indicates this is so) PetscMallocAlign allocate a little
>>> extra space and aligns the result, leaving a few bytes uninitialized
>>> (memory further away may also be uninitialized, but this error isn't
>>> saying complaining about those places).
>>> Jed
>> Department of Applied Physics and Applied Mathematics
>> Columbia University
>> Tel:917-399-8032
>> www.columbia.edu/~xy2102
Columbia University
Tel:917-399-8032
