[petsc-users] valgrind errors.
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Tue Jan 19 12:27:14 CST 2010
Dear Jed,
I switched the code as below and it is working now without valgrind errors.
I am using multilevel, will the following approach be fine? I will
modify the code a little more to get sth like yours.
typedef struct {
PetscReal x1,x2,x3,x4;
} FieldOther;
#undef __FUNCT__
#define __FUNCT__ "FormFunction"
PetscErrorCode FormFunction(SNES snes,Vec X,Vec F,void*dummg)
DA dafieldother;
FieldOther **fieldother;
Vec FIELDOTHER;
PetscFunctionBegin;
ierr = DAGetLocalInfo((DA)dmmg->dm,&info);CHKERRQ(ierr);
ierr = DACreate2d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_BOX,
info.mx, info.my, PETSC_DECIDE, PETSC_DECIDE, 4, 2, 0, 0,
&dafieldother);CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 0, "x1");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 1, "x2");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 2, "x3");CHKERRQ(ierr);
ierr = DASetFieldName(dafieldother, 3, "x4");CHKERRQ(ierr);
ierr = DAGetLocalVector(dafieldother,&FIELDOTHER);CHKERRQ(ierr);
ierr = DAVecGetArray(dafieldother,FIELDOTHER,&fieldother);CHKERRQ(ierr);
for (j = jFirst; j <= jLast; j++){
for (i = iFirst; i <= iLast; i++){
fieldother[j][i].x1 = 0;
fieldother[j][i].x2 = 0;
fieldother[j][i].x3 = 0;
fieldother[j][i].x4 = 0;
ffield[j][i].x1 = fieldother[j][i].x1;
ierr =
DAVecRestoreArray(dafieldother,FIELDOTHER,&fieldother);CHKERRQ(ierr);
ierr = DARestoreLocalVector(dafieldother,&FIELDOTHER);CHKERRQ(ierr);
ierr = DADestroy(dafieldother);CHKERRQ(ierr);
PetscFunctionReturn(0);
Thanks so much!
Rebecca
Quoting Jed Brown <jed at 59A2.org>:
> On Tue, 19 Jan 2010 12:56:30 -0500, "(Rebecca) Xuefei YUAN"
> <xy2102 at columbia.edu> wrote:
>> Dear Jed,
>> I have one more question, what is the difference or how could I know
>> whether I need DAGetArray() or DAGetLocalVector()+DAVecGetArray() to
>> get my array?
> You can use the former unless you need to use it when packed up in a
> vector.
> In a mulitlevel scheme, I would probably put something like this in my
> FormFunction:
> DA da = (DA)dmmg->dm,eda;
> PetscObjectQuery((PetscObject)da,"ExtraDA",(PetscObject*)&eda);
> if (!eda) {
> // create eda based on the layout of da
> PetscObjectCompose((PetscObject)da,"ExtraDA",eda);
> DADestroy(eda); // give away ownership
> DAGetArray(eda,PETSC_TRUE,&extrafield); // or FALSE if you don't
> need ghost values
> DARestoreArray(eda,PETSC_TRUE,&extrafield);
> This way the memory is only allocated once, it will work with multiple
> levels, and get cleaned up when you are done.
> Jed
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
