[petsc-users] A flag for FormFunction.
Barry Smith
bsmith at mcs.anl.gov
Thu Jan 14 11:01:25 CST 2010
This isn't really a good solution.
Could you explain what you want to do differently with the
function and when, then we may have a better solution.
Barry
On Jan 14, 2010, at 10:50 AM, (Rebecca) Xuefei YUAN wrote:
> Dear Barry,
> Yes, I would like the FormFunction to do different things depending
> on if it is called by SNESComputeFunction.
> I found a solution to it, but I am not sure whether it is good/easy
> enough to track.
> I put up a integer "callNumber" into my user-defined contents, and
> set it to be 0 at the beginning of each time iteration.
> When FormFunction is called, it is first called by
> SNESComputeFunction, followed by other PETSc functions, so my if
> condition is
> if (callNumber==0){
> do A
> }else{
> do B
> Before PetscFunctionReturn(0),
> callNumber + = 1;
> So far it is good, and it did what I would like to.
> Is there a better way of doing it?
> Thanks a lot!
> Rebecca
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> There really isn't a mechanism to know by whom a function is called.
>> Do you want this so you know when the function is being called
>> directly vs when it is being called in computing a Jacobian
>> derivative
>> with finite differencing? Do you want the function to do something
>> different in the two cases?
>> Barry
>> On Jan 14, 2010, at 9:14 AM, (Rebecca) Xuefei YUAN wrote:
>>> Dear all,
>>> I would like to setup a flag for the FormFunction like:
>>> if (FormFunction is called by SNESComputeFunction){
>>> flag = 1;
>>> }else{
>>> flag = 0;
>>> Is there any way I can know which function called FormFunction? I
>>> can tell very clear in debug mode, but I need this information in
>>> the code.
>>> Thanks very much!
>>> Rebecca
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
