[petsc-users] MatSetValues for nonzeros of a sparse matrix
Wed Jan 13 09:21:20 CST 2010
On Wed, Jan 13, 2010 at 9:16 AM, Umut Tabak <u.tabak at tudelft.nl> wrote:
> Dear all,
> I am reading some FE system matrices from a commercial FE code. I wrote an
> interface where I export them in matrix market format. Also I keep the row
> and column indices of the non-zero values and as well the non-zeros values
> in arrays of proper type.
> The question which I could not conclude is that how to use MatSetValues for
> sparse matrix assignments, I mean should I keep all the values(non-zeros
> also) in my inputs?( There are also some pointers for block assignments but
> they work in the same way I guess)
> I have tested with the below code. If I supply only the non-zero diagonal
> entries, I get the first row set as expected but this did not seem so
> practical to me, because to get what I want accomplished I should keep all
> the zero entries as well. And I thought that there should be a far more
> efficient way to apply this. (Diagonal assignment is just an example.) I am
> sorry if this question is too naive :)
> Any comments is appreciated.
> Best regards,
> Umut
>  Mat            A;             /* linear system matrix */
>  PetscErrorCode ierr;
>  PetscInt       n = 4;
>  PetscInt       rI=0,cI=0;
>  PetscViewer    viewer;
>  PetscInt index;
>  // row indices,m column indices,n of Matrix A
>  const int idxm[] = { 0,1,2,3 };
>  const int idxn[] = { 0,1,2,3 };
>  // values in the matrix A, row major order
>  PetscScalar valuesMat[]={ 1,0,0,0,0,2,0,0,0,0,3,0,0,0,0,4 };
>  //PetscScalar valuesMat[]={ 1,2,3,4 };
>  /* should be the 1st call after the declaration and definition
>   * block
>  PetscInitialize(&argc,&args,(char *)0,help);
>  // added by U.Tabak
>  // intermediate assigments are
>  // set the values of the Matrix A
>  ierr = MatSetValues(A, n, idxm, n, idxn, valuesMat,INSERT_VALUES);
> CHKERRQ(ierr);
Should be
  for(int r = 0; r < 4; ++r) {
    MatSetValues(A, 1, idxm[r], 1, idxn[r], &valuesMat[r*4+r],
INSERT_VALUES);
The simplest way to use MatSetValues is to call it once per row.
   Matt
>  // done so the 2nd argument should be
>  // MAT_FLUSH_ASSEMBLY
>  ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>  CHKERRQ(ierr);
>  ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
> CHKERRQ(ierr);
>  ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);
> CHKERRQ(ierr);
>    ierr = PetscFinalize();CHKERRQ(ierr);
>  return 0;
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100113/ae5798da/attachment.htm>
