[petsc-users] petsc 3.0 vs petsc 2.3
Wed Jan 13 08:27:53 CST 2010
Is this application making PETSc calls from fortran? You'll have to go
through the changes file - and make sure the prototype changes are
applied to your code [a fortran compiler doesn't help with prototype
checks here].
http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/300.html
[If the above doesn't catch all changes] use valgrind to figureout
which function/s are corrupting data - and then check if the code is
using the function prototype correctly [by verifying with the manpage]
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Corrupt
Satish
On Wed, 13 Jan 2010, Ildar Rakhmanov wrote:
> Hi:
> We have piece of code which is using Petsc linear equations solver in serial
> fashion.
> The version linked to Petsc 2.3.3.15 works fine.
> When we try to use Petsc 3.0.0.10 we start getting errors like this
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Corrupted Petsc object!
> [0]PETSC ERROR: Missing Inode Structure!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 10, Tue Nov 24 16:38:09
> CST 2009
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ****/driverFlow on a i686-pc-l named ******* by **** Mon
> Jan  4 18:49:59 2010
> [0]PETSC ERROR: Libraries linked from =/home/eni/local1/hpc/lib
> [0]PETSC ERROR: Configure run at Tue Dec 29 12:44:48 2009
> [0]PETSC ERROR: Configure options --prefix==****** --with-mpi=0
> --with-cc=gcc --with-fc=gfortran -with-cxx=g++ --download-f-blas-lapack=1
> --download-lusol=1 --download-superlu=1 --download-umfpack=1 --with-shared=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatSolve_Inode() line 793 in src/mat/impls/aij/seq/inode.c
> [0]PETSC ERROR: MatSolve() line 2624 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCApply_ILU() line 346 in src/ksp/pc/impls/factor/ilu/ilu.c
> [0]PETSC ERROR: PCApply() line 357 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPInitialResidual() line 57 in
> src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: KSPSolve_GMRES() line 241 in src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve() line 385 in src/ksp/ksp/interface/itfunc.c
> Could you please advise what can fix this problem?
> Ildar Khabibrakhmanov
