[petsc-users] Snes behavior
Barry Smith
bsmith at mcs.anl.gov
Sun Jan 10 16:57:05 CST 2010
JUST run with -snes_mf_operator and then with -snes_type test NOT
together,
Barry
On Jan 10, 2010, at 4:42 PM, Ryan Yan wrote:
> Hi Barry,
> Please see reply below,
> On Sun, Jan 10, 2010 at 4:57 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> On Jan 10, 2010, at 3:52 PM, Ryan Yan wrote:
> Hi Barry,
> Yes, exactly. The original multi-components system scale quite
> unevenly. I will try to rescale it.
> Could this be helpful to show some promise on quadratic convergence?
> I won't be concerned about "quadratic convergence" I'd only be
> concerned that it is converging to the correct answer and that you
> are getting close enough to the correct answer.
> Yes, I agree.
> You can run with -snes_mf_operator and -snes_type test to verify
> if the Jacobian being computed is accurate. Perhaps in your function
> evaluation you are not using the stencil that you set with the DA,
> this would cause the wrong Jacobian to be computed.
> After passing in -snes_mf_operator and -snes_type test as follows:
> vyan2000 at vyan2000-linux ~/NCproject/general : mpirun -np 2 ./
> HeatProfile1D -snes_mf_operator -snes_type test
> I got errors, as expected:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Cannot test with alternative preconditioner!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 5, Mon Apr 13
> 09:15:37 CDT 2009
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./HeatProfile1D on a O-hypre-p named vyan2000-linux
> by vyan2000 Sun Jan 10 17:16:00 2010
> [0]PETSC ERROR: Libraries linked from /home/vyan2000/local/PPETSc/
> petsc-3.0.0-p5/O-hypre-prometheus/lib
> [0]PETSC ERROR: Configure run at Thu Jun 25 13:49:36 2009
> [0]PETSC ERROR: Configure options --download-mpich=1 --with-
> debugger=gdb --download-hypre=1 --download-parmetis=1 --download-
> prometheus=1 --with-shared=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: SNESSolve_Test() line 28 in src/snes/impls/test/
> snestest.c
> [0]PETSC ERROR: SNESSolve() line 2221 in src/snes/interface/snes.c
> [0]PETSC ERROR: DMMGSolveSNES() line 510 in src/snes/utils/damgsnes.c
> [0]PETSC ERROR: DMMGSolve() line 372 in src/snes/utils/damg.c
> [0]PETSC ERROR: main() line 270 in /home/vyan2000/local/PPETSc/
> petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/
> NCprojectHeatProfile1D.c
> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0[cli_0]:
> aborting job:
> The error makes sense, since I did not pass in the analytical
> Jacobian for the preconditioner matrix. In stead, I was using
> DMMGSetSNESLocal(dmmg,FormFunctionLocal,
> 0,ad_FormFunctionLocal,admf_FormFunctionLocal). I am going to change
> the code a bit, pass in the analytical Jacobian and do the -
> snes_type test.
> I will bear your suggestion in mind during the test.
> Thanks a lot,
> Yan
> Barry
> Thanks a lot,
> Yan
> On Sun, Jan 10, 2010 at 4:35 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> You already got a 10^16 drop in the residual norm. It is not
> realistic to expect to get much more than that for double precision
> calculations. Perhaps your original F() has some funky scaling of
> different components that you can fix.
> Barry
> On Jan 10, 2010, at 2:55 PM, Ryan Yan wrote:
> Hi All,
> I am solving a nonlinear system using snes. The -snes_monitor option
> has the following output:
> 0 SNES Function norm 2.640163923729e+09
> 1 SNES Function norm 1.047643565314e+08
> 2 SNES Function norm 1.712732074788e+06
> 3 SNES Function norm 1.002169173269e+04
> 4 SNES Function norm 1.655878303433e+03
> 5 SNES Function norm 3.746498305706e+02
> 6 SNES Function norm 8.317435704773e+01
> 7 SNES Function norm 1.857639969641e+01
> 8 SNES Function norm 4.149691057773e+00
> 9 SNES Function norm 9.265604042412e-01
> 10 SNES Function norm 2.069527103214e-01
> 11 SNES Function norm 4.624186491082e-02
> 12 SNES Function norm 1.035558432688e-02
> 13 SNES Function norm 2.341362958811e-03
> 14 SNES Function norm 5.507445427277e-04
> 15 SNES Function norm 1.485123568354e-04
> 16 SNES Function norm 5.180043781814e-05
> 17 SNES Function norm 2.341966514486e-05
> 18 SNES Function norm 1.344936158651e-05
> 19 SNES Function norm 1.054812641176e-05
> Number of Newton iterations = 19
> Converged reason is 4
> It looks like the iterate never falls into a quadratic convergence
> region before it converges. Is there any hint to understand this
> behavior?
> Thanks a lot,
> Yan
