[petsc-users] command line option for superlu_dist
Hong Zhang
hzhang at mcs.anl.gov
Tue Jan 5 14:10:42 CST 2010
I got the matrix and start testing it:
- sequential mumps fails during numerical factorization
[0]PETSC ERROR: [0] MatFactorNumeric_MUMPS line 314 src/mat/impls/aij/
mpi/mumps/mumps.c
[0]PETSC ERROR: [0] MatLUFactorNumeric line 2378 src/mat/interface/
matrix.c
- sequential superlu seems hang ...
Something is wrong with your matrix. I'll further check it and let you
know
what I get.
How did you get mumps work? Sequential or parallel (num of processors?)?
Hong
On Jan 5, 2010, at 1:59 PM, Barry Smith wrote:
> Ok, we got the file. For "security reasons" ls is disabled in that
> directory.
> Barry
> On Jan 5, 2010, at 1:54 PM, hxie at umn.edu wrote:
>> I use ftp to upload the file matrix.gz to incoming. But I cannot
>> see it using 'ls'.
>> Hui
>> Likely SuperLU_Dist is failing on the provided matrix. Could you
>> use -ksp_view_binary on the run and copy the resulting file
>> binaryoutput to the anonymous ftp site ftp.mcs.anl.gov in the
>> directory incoming and tell us when the matrix is there. Sparse
>> parallel factorizations are a bit fragile and can fail.
>> Barry
