[petsc-users] Very poor speed up performance
Thu Dec 23 19:45:04 CST 2010
On Wed, Dec 22, 2010 at 6:32 PM, Jed Brown <jed at 59a2.org> wrote:
> I disagree, there is easily a factor of two in flop/s between a naive
> ordering (e.g. hierarchical by node type in a finite element method) and a
> good low-bandwidth ordering.
> This is in the FUN3D papers and still true today, in my experience.
There is no doubt that this difference can exist, but many mesh generators
(such as triangle) give back a good
ordering. FUN3D used an inexplicably bad ordering.
   Matt
> Incomplete factorization is also very order dependent, as you note.
> Jed
> On Dec 22, 2010 5:03 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Wed, Dec 22, 2010 at 10:11 AM, Yongjun Chen <yjxd.chen at gmail.com>
> wrote:
> > On Wed, Dec 22, 2010 at 6:53 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Wed, 22 De...
> 1) To see a large gain, the ordering you start with would have to be very
> bad. Maybe it is. These
>     orderings try to minimize bandwidth, which means minimize communication
> in the MatMult.
> 2) If you use incomplete facotrization, the ordering can have a large
> effect on conditioning, so
>     number of iterations, which does not improve scalability. This would
> impact scalability if you
>    use a parallel IC, however all those packages reorder your matrix
> already.
> In short, I suspect this will not help a lot, except maybe with
> conditioning, which is what I was refering to in the quote.
>     Matt
> experiments is infinitely more...
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101223/304e8830/attachment.htm>
