[petsc-users] Reading matrices into PETSc
Shri abhyshr at mcs.anl.gov
Wed Dec 22 03:41:21 CST 2010
Find attached a routine which reads matrix data from an ASCII file in i j value format and creates a seqaij matrix.
----- Original Message -----
I am sorry, but I am not yet clear on how to do this. I read ex32.c and ex72.c but I am still confused. What is ASCII 'slap' format? How should matrix be supplied to PETSc?
My matrix is a 2000x1900 matrix given in the format MATLAB stores sparse matrices. i.e [row, column, non-zero-entry] format.
On Tue, Dec 21, 2010 at 11:03 PM, Gaurish Telang < gaurish108 at gmail.com > wrote:
i have this large text file containing a matrix.
This text file contains the non-zero entries of a very large sparse matrix
The first two columns indicate the position of the non-zero entry
and the last column the actual non-zero value it self
for
example the matrix
1 0 8
0 0 5
6 0 0
is written in the text file in the form of
1 1 1
1 3 8
2 3 5
3 1 6
This is the standard [(row ,column), non-zero] entry format. i want PETSc to load this matrix
from the text file
i am not sure how
to do that. What commands do I use?
I am new to PETSc, so some detail in the explanation will be really helpful.
Sincere thanks,
Gaurish.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101222/0ddb21ee/attachment-0001.htm>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101222/0ddb21ee/attachment-0001.c>
