[petsc-users] Monotonic convergence in FGMRES.
Jed Brown
jed at 59A2.org
Tue Dec 21 14:08:01 CST 2010
On Tue, Dec 21, 2010 at 21:04, Barry Smith <bsmith at mcs.anl.gov> wrote:
> This is a sign that the preconditioner is seriously messed up and should
> not be used in its current form. It can happen if the matrix is nearly
> singular and for example you use an incomplete factorization for a
> preconditioner that just screws up the scaling like totally. Run with
> -ksp_monitor_true_residual and you'll see that the solver is not really
> solving the problem even though it thinks it is converging fine.
FGMRES only does right preconditioning so it should be showing the true
residual.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101221/330a8c09/attachment.htm>
