[petsc-users] Very poor speed up performance
Yongjun Chen yjxd.chen at gmail.com
Mon Dec 20 15:59:20 CST 2010
Matt, Barry, thanks a lot for your reply! I will try mpich hydra firstly and
see what I can get.
Yongjun
On Mon, Dec 20, 2010 at 8:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 20, 2010 at 10:38 AM, Yongjun Chen <yjxd.chen at gmail.com>wrote:
>> Hi Matt,
>> Thanks for your reply. Just now I have carried out a series of tests with
>> k=2, 4, 8, 12 and 16 cores on the first server again with the -log_summary
>> option. From 8 cores to 12 cores, a small speed up has been found this time,
>> but from 12 cores to 16 cores, the computation time increase!
>> Attached please find these 5 log files. Thank you very much!
> Its very clear from these, but Barry was right in his reply. These are
> memory bandwidth limited
> computations, so if you don't get any more bandwidth you will not speed up.
> This is rarely mentioned
> in sales pitches for multicore computers. LAMMPS is not limited by
> bandwidth for most computations.
>    Matt
>> mpiexec -n *k* ./AMG_Solver_MPI -pc_type jacobi -ksp_type bicg
>> -log_summary
>> Here, I use ksp bicg instead of gmres, because the two ksp gives almost
>> the same speed up performance, as I have tried many times.
>> (1) k=2
>> Process 1 of total 2 on wmss04
>> Process 0 of total 2 on wmss04
>> The dimension of Matrix A is n = 1177754
>> Begin Assembly:
>> Begin Assembly:
>> End Assembly.
>> End Assembly.
>> Begin the solving:
>> The current time is: Mon Dec 20 17:42:23 2010
>> KSP Object:
>>   type: bicg
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object:
>>   type: jacobi
>>   linear system matrix = precond matrix:
>>   Matrix Object:
>>     type=mpisbaij, rows=1177754, cols=1177754
>>     total: nonzeros=49908476, allocated nonzeros=49908476
>>         block size is 1
>> norm(b-Ax)=1.25862e-06
>> Norm of error 1.25862e-06, Iterations 1475
>> The solver has finished successfully!
>> The solving time is 762.874 seconds.
>> The time accuracy is 1e-06 second.
>> The current time is Mon Dec 20 17:55:06 2010
>> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
>> -fCourier9' to print this document            ***
>> ---------------------------------------------- PETSc Performance Summary:
>> ./AMG_Solver_MPI on a linux-gnu named wmss04 with 2 processors, by cheny
>> Mon Dec 20 18:55:06 2010
>> Using Petsc Release Version 3.1.0, Patch 5, Mon Sep 27 11:51:54 CDT 2010
>>                          Max       Max/Min        Avg      Total
>> Time (sec):           8.160e+02      1.00000   8.160e+02
>> Objects:              3.000e+01      1.00000   3.000e+01
>> Flops:                3.120e+11      1.04720   3.050e+11  6.100e+11
>> Flops/sec:            3.824e+08      1.04720   3.737e+08  7.475e+08
>> MPI Messages:         2.958e+03      1.00068   2.958e+03  5.915e+03
>> MPI Message Lengths:  9.598e+08      1.00034   3.245e+05  1.919e+09
>> MPI Reductions:       4.483e+03      1.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>>                             e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>>                             and VecAXPY() for complex vectors of length N
>> --> 8N flops
>> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>>                         Avg     %Total     Avg     %Total   counts
>> %Total     Avg         %Total   counts   %Total
>>  0:      Main Stage: 8.1603e+02 100.0%  6.0997e+11 100.0%  5.915e+03
>> 100.0%  3.245e+05      100.0%  4.467e+03  99.6%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>>    Count: number of times phase was executed
>>    Time and Flops: Max - maximum over all processors
>>                    Ratio - ratio of maximum to minimum over all processors
>>    Mess: number of messages sent
>>    Avg. len: average message length
>>    Reduct: number of global reductions
>>    Global: entire computation
>>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
>> PetscLogStagePop().
>>       %T - percent time in this phase         %F - percent flops in this
>> phase
>>       %M - percent messages in this phase     %L - percent message lengths
>> in this phase
>>       %R - percent reductions in this phase
>>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>> Event                Count      Time (sec)
>> Flops                             --- Global ---  --- Stage ---   Total
>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> MatMult             1476 1.0 3.4220e+02 1.0 1.48e+11 1.0 3.0e+03 3.2e+05
>> 0.0e+00 41 47 50 50  0  41 47 50 50  0   846
>> MatMultTranspose    1475 1.0 3.4208e+02 1.0 1.48e+11 1.0 3.0e+03 3.2e+05
>> 0.0e+00 42 47 50 50  0  42 47 50 50  0   846
>> MatAssemblyBegin       1 1.0 1.5492e-0281.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatAssemblyEnd         1 1.0 8.1615e-02 1.0 0.00e+00 0.0 1.0e+01 1.1e+05
>> 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
>> MatView                1 1.0 1.5807e-04 3.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecView                1 1.0 1.0809e+01 2.1 0.00e+00 0.0 2.0e+00 2.4e+06
>> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>> VecDot              2950 1.0 2.0457e+01 1.9 3.47e+09 1.0 0.0e+00 0.0e+00
>> 3.0e+03  2  1  0  0 66   2  1  0  0 66   340
>> VecNorm             1477 1.0 1.2103e+01 1.7 1.74e+09 1.0 0.0e+00 0.0e+00
>> 1.5e+03  1  1  0  0 33   1  1  0  0 33   287
>> VecCopy                4 1.0 1.0110e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecSet              8855 1.0 6.0069e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY             4426 1.0 1.8430e+01 1.2 5.21e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  2  0  0  0   2  2  0  0  0   566
>> VecAYPX             2948 1.0 1.3610e+01 1.2 3.47e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   510
>> VecAssemblyBegin       6 1.0 9.1116e-0317.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> 1.8e+01  0  0  0  0  0   0  0  0  0  0     0
>> VecAssemblyEnd         6 1.0 1.7405e-05 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecPointwiseMult    2952 1.0 1.7966e+01 1.1 1.74e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   194
>> VecScatterBegin     2951 1.0 8.6552e-01 1.1 0.00e+00 0.0 5.9e+03 3.2e+05
>> 0.0e+00  0  0100100  0   0  0100100  0     0
>> VecScatterEnd       2951 1.0 2.7126e+01 8.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>> KSPSetup               1 1.0 3.9254e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 7.5170e+02 1.0 3.12e+11 1.0 5.9e+03 3.2e+05
>> 4.4e+03 92100100100 99  92100100100 99   811
>> PCSetUp                1 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> PCApply             2952 1.0 1.8043e+01 1.1 1.74e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   193
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions     Memory  Descendants'
>> Mem.
>> Reports information only for process 0.
>>               Matrix     3              3    339744648     0
>>                  Vec    18             18     62239872     0
>>          Vec Scatter     2              2         1736     0
>>            Index Set     4              4       974736     0
>>        Krylov Solver     1              1          832     0
>>       Preconditioner     1              1          872     0
>>               Viewer     1              1          544     0
>> Average time to get PetscTime(): 1.21593e-06
>> Average time for MPI_Barrier(): 1.44005e-05
>> Average time for zero size MPI_Send(): 1.94311e-05
>> #PETSc Option Table entries:
>> -ksp_type bicg
>> -log_summary
>> -pc_type jacobi
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8
>> Configure run at: Tue Nov 23 15:54:45 2010
>> Configure options: --known-level1-dcache-size=65536
>> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=2
>> --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
>> --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
>> --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
>> --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4
>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=gcc
>> --with-cxx=g++ --with-F77=ifort --with-FC=ifort --download-f-blas-lapack=1
>> --download-superlu-dist=1 --download-hypre=1 --download-trilinos=1
>> --download-parmetis=1 --download-mumps=1 --download-scalapack=1
>> --download-blacs=1 --download-mpich=1 --with-debugging=0 --with-batch
>> --known-mpi-shared=1
>> Libraries compiled on Tue Nov 23 15:57:11 CET 2010 on wmss04
>> Machine characteristics: Linux wmss04 2.6.16.60-0.21-smp #1 SMP Tue May 6
>> 12:41:02 UTC 2008 x86_64 x86_64 x86_64 GNU/Linux
>> Using PETSc directory: /sun42/cheny/petsc-3.1-p5-optimized
>> Using PETSc arch: linux-gnu-c-opt
>> Using C compiler:
>> /sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/bin/mpicc -Wall
>> -Wwrite-strings -Wno-strict-aliasing -O
>> Using Fortran compiler:
>> /sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/bin/mpif90 -Wall
>> -Wno-unused-variable -O
>> Using include paths:
>> -I/sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/include
>> -I/sun42/cheny/petsc-3.1-p5-optimized/include
>> Using C linker:
>> Using Fortran linker:
>> Using libraries:
>> -Wl,-rpath,/sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/lib
>> -L/sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/lib -lpetsc
>> -L/sun42/cheny/petsc-3.1-p5-optimized/linux-gnu-c-opt/lib -lHYPRE -lmpichcxx
>> -lstdc++ -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
>> -lparmetis -lmetis -lscalapack -lblacs -lflapack -lfblas -lnsl -laio -lrt
>> -L/usr/lib64/gcc/x86_64-suse-linux/4.1.2
>> -L/opt/intel/Compiler/11.0/083/ipp/em64t/lib
>> -L/opt/intel/Compiler/11.0/083/mkl/lib/em64t
>> -L/opt/intel/Compiler/11.0/083/tbb/em64t/cc4.1.0_libc2.4_kernel2.6.16.21/lib
>> -L/usr/x86_64-suse-linux/lib -ldl -lmpich -lpthread -lrt -lgcc_s -lmpichf90
>> -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lmpich
>> -lpthread -lrt -lgcc_s -ldl
>> (2) k=4
>> Process 0 of total 4 on wmss04
>> Process 2 of total 4 on wmss04
>> Process 3 of total 4 on wmss04
>> Process 1 of total 4 on wmss04
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> Begin the solving:
>> The current time is: Mon Dec 20 17:33:24 2010
>> KSP Object:
>>   type: bicg
>> PC Object:
>>   type: jacobi
>>   Matrix Object:
>>         block size is 1
>> norm(b-Ax)=1.28342e-06
>> Norm of error 1.28342e-06, Iterations 1473
>> The solving time is 450.583 seconds.
>> The current time is Mon Dec 20 17:40:55 2010
>> ./AMG_Solver_MPI on a linux-gnu named wmss04 with 4 processors, by cheny
>> Mon Dec 20 18:40:55 2010
>> Time (sec):           4.807e+02      1.00000   4.807e+02
>> Flops:                1.558e+11      1.06872   1.523e+11  6.091e+11
>> Flops/sec:            3.241e+08      1.06872   3.168e+08  1.267e+09
>> MPI Messages:         5.906e+03      2.00017   4.430e+03  1.772e+04
>> MPI Message Lengths:  1.727e+09      2.74432   2.658e+05  4.710e+09
>> MPI Reductions:       4.477e+03      1.00000
>> --> 2N flops
>> --> 8N flops
>>  0:      Main Stage: 4.8066e+02 100.0%  6.0914e+11 100.0%  1.772e+04
>> 100.0%  2.658e+05      100.0%  4.461e+03  99.6%
>> Phase summary info:
>> PetscLogStagePop().
>> phase
>> in this phase
>> MatMult             1474 1.0 1.9344e+02 1.1 7.40e+10 1.1 8.8e+03 2.7e+05
>> 0.0e+00 39 47 50 50  0  39 47 50 50  0  1494
>> MatMultTranspose    1473 1.0 1.9283e+02 1.0 7.40e+10 1.1 8.8e+03 2.7e+05
>> 0.0e+00 40 47 50 50  0  40 47 50 50  0  1498
>> MatAssemblyBegin       1 1.0 1.5624e-0263.8 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         1 1.0 6.3599e-02 1.0 0.00e+00 0.0 3.0e+01 9.3e+04
>> MatView                1 1.0 1.8096e-04 2.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecView                1 1.0 1.1063e+01 4.7 0.00e+00 0.0 6.0e+00 1.2e+06
>> VecDot              2946 1.0 2.5350e+01 2.7 1.73e+09 1.0 0.0e+00 0.0e+00
>> 2.9e+03  3  1  0  0 66   3  1  0  0 66   274
>> VecNorm             1475 1.0 1.1197e+01 3.0 8.69e+08 1.0 0.0e+00 0.0e+00
>> 1.5e+03  1  1  0  0 33   1  1  0  0 33   310
>> VecCopy                4 1.0 6.0010e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecSet              8843 1.0 3.6737e+00 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY             4420 1.0 1.4221e+01 1.4 2.60e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  3  2  0  0  0   3  2  0  0  0   732
>> VecAYPX             2944 1.0 1.1377e+01 1.1 1.73e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   610
>> VecAssemblyBegin       6 1.0 2.8596e-0223.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd         6 1.0 2.4796e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecPointwiseMult    2948 1.0 1.7210e+01 1.2 8.68e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  3  1  0  0  0   3  1  0  0  0   202
>> VecScatterBegin     2947 1.0 1.9806e+00 2.4 0.00e+00 0.0 1.8e+04 2.7e+05
>> VecScatterEnd       2947 1.0 4.3833e+01 7.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
>> KSPSetup               1 1.0 2.1496e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 4.3931e+02 1.0 1.56e+11 1.1 1.8e+04 2.7e+05
>> 4.4e+03 91100100100 99  91100100100 99  1386
>> PCSetUp                1 1.0 3.0994e-06 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> PCApply             2948 1.0 1.7256e+01 1.2 8.68e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  3  1  0  0  0   3  1  0  0  0   201
>> Mem.
>>               Matrix     3              3    169902696     0
>>                  Vec    18             18     31282096     0
>>            Index Set     4              4       638616     0
>>               Viewer     1              1          544     0
>> Average time to get PetscTime(): 1.5974e-06
>> Average time for MPI_Barrier(): 3.48091e-05
>> Average time for zero size MPI_Send(): 1.8537e-05
>> -ksp_type bicg
>> -log_summary
>> -pc_type jacobi
>> (3) k=8
>> Process 0 of total 8 on wmss04
>> Process 4 of total 8 on wmss04
>> Process 2 of total 8 on wmss04
>> Process 6 of total 8 on wmss04
>> Process 3 of total 8 on wmss04
>> Process 7 of total 8 on wmss04
>> Process 1 of total 8 on wmss04
>> Process 5 of total 8 on wmss04
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> Begin the solving:
>> The current time is: Mon Dec 20 18:14:59 2010
>> KSP Object:
>>   type: bicg
>> PC Object:
>>   type: jacobi
>>   Matrix Object:
>>         block size is 1
>> norm(b-Ax)=1.32502e-06
>> Norm of error 1.32502e-06, Iterations 1473
>> The solving time is 311.937 seconds.
>> The current time is Mon Dec 20 18:20:11 2010
>> ./AMG_Solver_MPI on a linux-gnu named wmss04 with 8 processors, by cheny
>> Mon Dec 20 19:20:11 2010
>> Time (sec):           3.330e+02      1.00000   3.330e+02
>> Flops:                7.792e+10      1.09702   7.614e+10  6.091e+11
>> Flops/sec:            2.340e+08      1.09702   2.286e+08  1.829e+09
>> MPI Messages:         5.906e+03      2.00017   5.169e+03  4.135e+04
>> MPI Message Lengths:  1.866e+09      4.61816   2.430e+05  1.005e+10
>> --> 2N flops
>> --> 8N flops
>>  0:      Main Stage: 3.3302e+02 100.0%  6.0914e+11 100.0%  4.135e+04
>> 100.0%  2.430e+05      100.0%  4.461e+03  99.6%
>> Phase summary info:
>> PetscLogStagePop().
>> phase
>> in this phase
>> MatMult             1474 1.0 1.4230e+02 1.4 3.70e+10 1.1 2.1e+04 2.4e+05
>> 0.0e+00 38 47 50 50  0  38 47 50 50  0  2031
>> MatMultTranspose    1473 1.0 1.3627e+02 1.1 3.70e+10 1.1 2.1e+04 2.4e+05
>> 0.0e+00 38 47 50 50  0  38 47 50 50  0  2120
>> MatAssemblyBegin       1 1.0 8.0800e-0324.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         1 1.0 5.3647e-02 1.0 0.00e+00 0.0 7.0e+01 8.5e+04
>> MatView                1 1.0 2.1791e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecView                1 1.0 1.0902e+0112.1 0.00e+00 0.0 1.4e+01 5.9e+05
>> VecDot              2946 1.0 3.5689e+01 7.6 8.67e+08 1.0 0.0e+00 0.0e+00
>> 2.9e+03  6  1  0  0 66   6  1  0  0 66   194
>> VecNorm             1475 1.0 8.1093e+00 4.0 4.34e+08 1.0 0.0e+00 0.0e+00
>> 1.5e+03  1  1  0  0 33   1  1  0  0 33   428
>> VecCopy                4 1.0 5.2011e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecSet              8843 1.0 3.0491e+00 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY             4420 1.0 9.2421e+00 1.6 1.30e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  2  0  0  0   2  2  0  0  0  1127
>> VecAYPX             2944 1.0 6.8297e+00 1.5 8.67e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0  1015
>> VecAssemblyBegin       6 1.0 2.6218e-0210.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd         6 1.0 3.6240e-05 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecPointwiseMult    2948 1.0 9.6646e+00 1.4 4.34e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  3  1  0  0  0   3  1  0  0  0   359
>> VecScatterBegin     2947 1.0 2.2599e+00 2.3 0.00e+00 0.0 4.1e+04 2.4e+05
>> 0.0e+00  1  0100100  0   1  0100100  0     0
>> VecScatterEnd       2947 1.0 7.7004e+0120.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  9  0  0  0  0   9  0  0  0  0     0
>> KSPSetup               1 1.0 1.4287e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 3.0090e+02 1.0 7.79e+10 1.1 4.1e+04 2.4e+05
>> 4.4e+03 90100100100 99  90100100100 99  2024
>> PCSetUp                1 1.0 4.0531e-06 2.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> PCApply             2948 1.0 9.7001e+00 1.4 4.34e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  3  1  0  0  0   3  1  0  0  0   358
>> Mem.
>>               Matrix     3              3     84944064     0
>>                  Vec    18             18     15741712     0
>>            Index Set     4              4       409008     0
>>               Viewer     1              1          544     0
>> Average time to get PetscTime(): 3.38554e-06
>> Average time for MPI_Barrier(): 7.40051e-05
>> Average time for zero size MPI_Send(): 1.88947e-05
>> -ksp_type bicg
>> -log_summary
>> -pc_type jacobi
>> (4) k=12
>> Process 1 of total 12 on wmss04
>> Process 5 of total 12 on wmss04
>> Process 2 of total 12 on wmss04
>> Process 9 of total 12 on wmss04
>> Process 6 of total 12 on wmss04
>> Process 7 of total 12 on wmss04
>> Process 10 of total 12 on wmss04
>> Process 3 of total 12 on wmss04
>> Process 11 of total 12 on wmss04
>> Process 4 of total 12 on wmss04
>> Process 8 of total 12 on wmss04
>> Process 0 of total 12 on wmss04
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> Begin the solving:
>> The current time is: Mon Dec 20 17:56:36 2010
>> KSP Object:
>>   type: bicg
>> PC Object:
>>   type: jacobi
>>   Matrix Object:
>>         block size is 1
>> norm(b-Ax)=1.28414e-06
>> Norm of error 1.28414e-06, Iterations 1473
>> The solving time is 291.503 seconds.
>> The current time is Mon Dec 20 18:01:28 2010
>> ./AMG_Solver_MPI on a linux-gnu named wmss04 with 12 processors, by cheny
>> Mon Dec 20 19:01:28 2010
>> Time (sec):           3.089e+02      1.00012   3.089e+02
>> Flops:                5.197e+10      1.11689   5.074e+10  6.089e+11
>> Flops/sec:            1.683e+08      1.11689   1.643e+08  1.971e+09
>> MPI Messages:         5.906e+03      2.00017   5.415e+03  6.498e+04
>> MPI Message Lengths:  1.887e+09      6.23794   2.345e+05  1.524e+10
>> --> 2N flops
>> --> 8N flops
>>  0:      Main Stage: 3.0887e+02 100.0%  6.0890e+11 100.0%  6.498e+04
>> 100.0%  2.345e+05      100.0%  4.461e+03  99.6%
>> Phase summary info:
>> PetscLogStagePop().
>> phase
>> in this phase
>> MatMult             1474 1.0 1.4069e+02 2.1 2.47e+10 1.1 3.2e+04 2.3e+05
>> 0.0e+00 35 47 50 50  0  35 47 50 50  0  2054
>> MatMultTranspose    1473 1.0 1.3272e+02 1.8 2.47e+10 1.1 3.2e+04 2.3e+05
>> 0.0e+00 34 47 50 50  0  34 47 50 50  0  2175
>> MatAssemblyBegin       1 1.0 6.4070e-0314.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         1 1.0 6.2698e-02 1.0 0.00e+00 0.0 1.1e+02 8.2e+04
>> MatView                1 1.0 2.4605e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecView                1 1.0 1.1164e+0182.6 0.00e+00 0.0 2.2e+01 3.9e+05
>> VecDot              2946 1.0 1.1499e+0234.8 5.78e+08 1.0 0.0e+00 0.0e+00
>> 2.9e+03 13  1  0  0 66  13  1  0  0 66    60
>> VecNorm             1475 1.0 1.0804e+01 7.7 2.90e+08 1.0 0.0e+00 0.0e+00
>> 1.5e+03  2  1  0  0 33   2  1  0  0 33   322
>> VecCopy                4 1.0 6.9451e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecSet              8843 1.0 2.9336e+00 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY             4420 1.0 1.0803e+01 2.3 8.68e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  2  0  0  0   2  2  0  0  0   964
>> VecAYPX             2944 1.0 6.6637e+00 2.1 5.78e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0  1041
>> VecAssemblyBegin       6 1.0 3.7719e-0214.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd         6 1.0 5.3883e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecPointwiseMult    2948 1.0 8.7972e+00 2.3 2.89e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   395
>> VecScatterBegin     2947 1.0 3.3624e+00 4.3 0.00e+00 0.0 6.5e+04 2.3e+05
>> VecScatterEnd       2947 1.0 8.0508e+0119.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 12  0  0  0  0  12  0  0  0  0     0
>> KSPSetup               1 1.0 1.1752e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 2.8016e+02 1.0 5.20e+10 1.1 6.5e+04 2.3e+05
>> 4.4e+03 91100100100 99  91100100100 99  2173
>> PCSetUp                1 1.0 5.9605e-06 2.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> PCApply             2948 1.0 8.8313e+00 2.3 2.89e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   393
>> Mem.
>>               Matrix     3              3     56593044     0
>>                  Vec    18             18     10534536     0
>>            Index Set     4              4       305424     0
>>               Viewer     1              1          544     0
>> Average time to get PetscTime(): 6.48499e-06
>> Average time for MPI_Barrier(): 0.000102377
>> Average time for zero size MPI_Send(): 2.15967e-05
>> -ksp_type bicg
>> -log_summary
>> -pc_type jacobi
>> (5) k=16
>> Process 0 of total 16 on wmss04
>> Process 8 of total 16 on wmss04
>> Process 4 of total 16 on wmss04
>> Process 12 of total 16 on wmss04
>> Process 2 of total 16 on wmss04
>> Process 6 of total 16 on wmss04
>> Process 5 of total 16 on wmss04
>> Process 11 of total 16 on wmss04
>> Process 14 of total 16 on wmss04
>> Process 7 of total 16 on wmss04
>> Process Process 15 of total 16 on wmss04
>> 3Process 13 of total 16 on wmss04
>> Process 10 of total 16 on wmss04
>> Process 9 of total 16 on wmss04
>> Process 1 of total 16 on wmss04
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> Begin Assembly:
>> End Assembly.
>> End Assembly.End Assembly.End Assembly.End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> End Assembly.
>> Begin the solving:
>> The current time is: Mon Dec 20 18:02:28 2010
>> KSP Object:
>>   type: bicg
>> PC Object:
>>   type: jacobi
>>   Matrix Object:
>>         block size is 1
>> norm(b-Ax)=1.15892e-06
>> Norm of error 1.15892e-06, Iterations 1497
>> The solving time is 337.91 seconds.
>> The current time is Mon Dec 20 18:08:06 2010
>> ./AMG_Solver_MPI on a linux-gnu named wmss04 with 16 processors, by cheny
>> Mon Dec 20 19:08:06 2010
>> Time (sec):           3.534e+02      1.00001   3.534e+02
>> Flops:                3.964e+10      1.13060   3.864e+10  6.182e+11
>> Flops/sec:            1.122e+08      1.13060   1.093e+08  1.749e+09
>> MPI Messages:         1.200e+04      3.99917   7.127e+03  1.140e+05
>> MPI Message Lengths:  1.950e+09      7.80999   1.819e+05  2.074e+10
>> MPI Reductions:       4.549e+03      1.00000
>> --> 2N flops
>> --> 8N flops
>>  0:      Main Stage: 3.5342e+02 100.0%  6.1820e+11 100.0%  1.140e+05
>> 100.0%  1.819e+05      100.0%  4.533e+03  99.6%
>> Phase summary info:
>> PetscLogStagePop().
>> phase
>> in this phase
>> MatMult             1498 1.0 1.8860e+02 1.7 1.88e+10 1.1 5.7e+04 1.8e+05
>> 0.0e+00 40 47 50 50  0  40 47 50 50  0  1555
>> MatMultTranspose    1497 1.0 1.4165e+02 1.3 1.88e+10 1.1 5.7e+04 1.8e+05
>> 0.0e+00 35 47 50 50  0  35 47 50 50  0  2069
>> MatAssemblyBegin       1 1.0 1.0044e-0217.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         1 1.0 7.3835e-02 1.0 0.00e+00 0.0 1.8e+02 6.7e+04
>> MatView                1 1.0 2.6107e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecView                1 1.0 1.1282e+01109.0 0.00e+00 0.0 3.0e+01 2.9e+05
>> VecDot              2994 1.0 6.7490e+0119.6 4.41e+08 1.0 0.0e+00 0.0e+00
>> 3.0e+03 10  1  0  0 66  10  1  0  0 66   104
>> VecNorm             1499 1.0 1.3431e+0110.8 2.21e+08 1.0 0.0e+00 0.0e+00
>> 1.5e+03  2  1  0  0 33   2  1  0  0 33   263
>> VecCopy                4 1.0 7.3178e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecSet              8987 1.0 3.1772e+00 3.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAXPY             4492 1.0 1.1361e+01 3.1 6.61e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  2  0  0  0   2  2  0  0  0   931
>> VecAYPX             2992 1.0 7.3248e+00 2.5 4.40e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  1  1  0  0  0   1  1  0  0  0   962
>> VecAssemblyBegin       6 1.0 3.6338e-0212.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd         6 1.0 7.2002e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecPointwiseMult    2996 1.0 9.7892e+00 2.4 2.21e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   360
>> VecScatterBegin     2995 1.0 4.0570e+00 5.5 0.00e+00 0.0 1.1e+05 1.8e+05
>> VecScatterEnd       2995 1.0 1.7309e+0251.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 22  0  0  0  0  22  0  0  0  0     0
>> KSPSetup               1 1.0 1.3058e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> KSPSolve               1 1.0 3.2641e+02 1.0 3.96e+10 1.1 1.1e+05 1.8e+05
>> 4.5e+03 92100100100 99  92100100100 99  1893
>> PCSetUp                1 1.0 8.1062e-06 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>> PCApply             2996 1.0 9.8336e+00 2.4 2.21e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00  2  1  0  0  0   2  1  0  0  0   359
>> Mem.
>>               Matrix     3              3     42424600     0
>>                  Vec    18             18      7924896     0
>>            Index Set     4              4       247632     0
>>               Viewer     1              1          544     0
>> Average time to get PetscTime(): 6.10352e-06
>> Average time for MPI_Barrier(): 0.000129986
>> Average time for zero size MPI_Send(): 2.08169e-05
>> -ksp_type bicg
>> -log_summary
>> -pc_type jacobi
>> On Mon, Dec 20, 2010 at 6:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Dec 20, 2010 at 8:46 AM, Yongjun Chen <yjxd.chen at gmail.com>wrote:
>>>> Hi everyone,
>>>> I use PETSC (version 3.1-p5) to solve a linear problem Ax=b. The matrix
>>>> A and right hand vector b are read from files. The dimension of A is
>>>> 1.2Million*1.2Million. I am pretty sure the matrix A and vector b have been
>>>> read correctly.
>>>> I compiled the program with optimized version (--with-debugging=0),
>>>> tested the speed up performance on two servers, and I have found that the
>>>> performance is very poor.
>>>> For the two servers, one is 4 cpus * 4 cores per cpu, i.e., with a total
>>>> 16 cores. And the other one is 4 cpus * 12 cores per cpu, with a total 48
>>>> cores.
>>>> On each of them, with the increasing of computing cores k from 1 to 8
>>>> (mpiexec –n  k ./Solver_MPI -pc_type jacobi -ksp-type gmres), the speed up
>>>> will increase from 1 to 6, but when the computing cores k increase from 9 to
>>>> 16(for the first server) or 48 (for the second server), the speed up
>>>> decrease firstly and then remains a constant value 5.0 (for the first
>>>> server) or 4.5(for the second server).
>>> We cannot say anything at all without -log_summary data for your runs.
>>>    Matt
>>>>  Actually, the program LAMMPS speed up excellently on these two
>>>> servers.
>>>> Any comments are very appreciated! Thanks!
>>>> PS: the related codes are as following,
>>>> //firstly read A and b from files
>>>> //then
>>>>               ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>>> CHKERRQ(ierr);
>>>>               ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>>> CHKERRQ(ierr);
>>>>               ierr = VecAssemblyBegin(b); CHKERRQ(ierr);
>>>>               ierr = VecAssemblyEnd(b); CHKERRQ(ierr);
>>>>               ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);
>>>> CHKERRQ(ierr);
>>>>               ierr = MatGetRowUpperTriangular(A); CHKERRQ(ierr);
>>>>               ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>               ierr =
>>>> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
>>>>               ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>>>               ierr =
>>>> KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>>>>               ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>               ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>>>               ierr =
>>>> KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>>>               ierr = KSPGetSolution(ksp, &x);CHKERRQ(ierr);
>>>>               ierr = VecAssemblyBegin(x);CHKERRQ(ierr);
>>>>               ierr = VecAssemblyEnd(x);CHKERRQ(ierr);
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Dr.Yongjun Chen
>> Room 2507, Building M
>> Institute of Materials Science and Technology
>> Technical University of Hamburg-Harburg
>> Eißendorfer Straße 42, 21073 Hamburg, Germany.
>> Tel:  +49 (0)40-42878-4386
>> Fax: +49 (0)40-42878-4070
>> E-mail: yjxd.chen at gmail.com
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101220/79c6179b/attachment-0001.htm>
