[petsc-users] Why cannot ParMetis and Scotch be intergrated togther?
Fri Dec 17 12:47:21 CST 2010
   They use to not be able to coexist in the same build. If Scotch has been properly fixed and you can figure out how to change Scotch's configuration to coexist we would be happy to accept the patch. We don't have the resources to fix a problem induced by someone else's very poor library design.
   Barry
On Dec 17, 2010, at 11:53 AM, Keita Teranishi wrote:
> Hi,
> I found PETSc’s configure script fails to integrate ParMetis and Scotch together.    I think Scotch has a option to rename it’s ParMetis API to eliminate entry point duplications.  Or is there any reason PETSc cannot put them together?
> Thanks,
>  Keita Teranishi
>  Scientific Library Group
>  Cray, Inc.
>  keita at cray.com
