[petsc-users] class templates in C++ and Petsc functions
Umut Tabak u.tabak at tudelft.nl
Mon Dec 13 09:11:41 CST 2010
Dear all,
I was trying to write a simple class template code to interface Petsc
matrices along with Boost sparse matrices and vice versa. However, my
first naive try did not work out of the box, since the template class
requires some functions from PETSc libraries and these functions should
be located in the object files to be able to compile. Since class
template is header only and there is no object code generation, it can
not find the PETSc library functions which is logical. I am also new to
templates in C++. I just gave a try to create a template class instead
of code duplication however it did not end up as expected. Are there
some smarter ways to accomplish this task. The function analyzes a boost
csr matrix and sets the rows of a Petsc matrix. T is for boost matrices
and T1 for Mat in Petsc. I can also get some comments on the code ;)
Best regards,
Umut
template <class T, class T1>
int converter<T, T1>::convertMBo2Pe( const T& A,
        T1 A_ ){
     PetscErrorCode ierr;
     int cntNnz = 0;
     typedef typename T::iterator1 i1_t;
     typedef typename T::iterator2 i2_t;
     //int nnz[ooFelieMatrix.size1()];
     int nnz[A.size1()];
     unsigned ind=0;
     //get information about the matrix
     double* vals = NULL;
     for (i1_t i1 = A.begin1(); i1 != A.end1(); ++i1)
       nnz[ind] = distance(i1.begin(), i1.end());
       ind++;
     // create the matrix depending
     // on the values of the nonzeros
     // on each row
     ierr = MatCreateSeqAIJ( PETSC_COMM_SELF, A.size1(),
                                                   A.size2(), cntNnz, nnz,
                                                   A_ );
     PetscInt rInd = 0, cInd=0;
     PetscInt* rCount, dummy;
     rCount = &dummy;
     // pointer to values in a row
     PetscScalar*   valsOfRowI = NULL;
     PetscInt*  colIndexOfRowI = NULL;
     PetscInt rC = 1;
     for(i1_t i1 = A.begin1(); i1 != A.end1(); ++i1)
       // allocate space for the values of row I
       valsOfRowI     = new PetscScalar[nnz[rInd]];
       colIndexOfRowI = new PetscInt[nnz[rInd]];
       for(i2_t i2 = i1.begin(); i2 != i1.end(); ++i2)
          colIndexOfRowI[cInd] = i2.index2();
          valsOfRowI[cInd]     = *i2;
          cInd++;
       // setting one row each time
       *rCount = rInd;
       MatSetValues( A_, rC, rCount, nnz[rInd],
                                   colIndexOfRowI, valsOfRowI,
                   INSERT_VALUES );
       // delete
       delete [] valsOfRowI;
       delete [] colIndexOfRowI;
       rInd++; cInd = 0;
     MatAssemblyBegin( A_, MAT_FINAL_ASSEMBLY );
     MatAssemblyEnd( A_, MAT_FINAL_ASSEMBLY );
     // return
     return 0;
  - Hope is a good thing, maybe the best of things
    and no good thing ever dies...
  The Shawshank Redemption, replique of Tim Robbins
