[petsc-users] About the "PetscOptionsSetValue" usage
Jed Brown jed at 59A2.org
Mon Dec 13 00:43:26 CST 2010
On Sun, Dec 12, 2010 at 22:35, Filippo Spiga
<filippo.spiga at disco.unimib.it>wrote:
> What can I do to remove the option "-c" inside the internal PETSc option
> database?
PetscOptionsClearValue()
> Is there a routine that reset/empty completely the internal PETSc database
> option without terminate the program?
PetscOptionsClear()
> Or the only way is to assign a different prefix for every program
> iteration?
What do you have to change differently on each iteration, but want to read
from a config file?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101212/a1b94c3f/attachment.htm>
