[petsc-users] global index distributed arrays
Matthew Knepley
knepley at gmail.com
Fri Dec 10 19:01:46 CST 2010
On Sat, Dec 11, 2010 at 12:56 AM, Jed Brown <jed at 59a2.org> wrote:
> On Sat, Dec 11, 2010 at 01:53, Matthew Knepley <knepley at gmail.com> wrote:
>> What are you guys talking about? He is asking ("global index for any given
>> 3-d index") for a map
>> (i, j, k) --> ((k*N + j)*M + i)*C + c
>> I can't imagine what you are searching for? The process which owns a given
>> index does not involve a search.
> The "global index" is in the "PETSc ordering". He wants this index for an
> arbitrary (i,j,k) which are not in the ghosted patch of the current process.
> You either have to store the full mapping, on search lx,ly,lz to locate the
> owner, then compute the index relative to that process. I don't think that
> code exists in PETSc. It wouldn't be too hard to write, but it's not the
> most beautiful thing to do.
I am not sure why you would need to access regions outside your local piece.
For instance,
consider how we treat boundary conditions. This is access to a fixed index,
but we check on
each process
if (i == i_bc) { <apply BC> }
Can't you do the same thing with your extra rows?
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101211/9b689383/attachment.htm>
