[petsc-users] pets-3.1-p6 with CUDA: Unknown vector type: cuda!
Jakub Pola jakub.pola at gmail.com
Thu Dec 9 17:07:45 CST 2010
Hi again,
I downloaded Petsc 3.1.0 as well as thrust 1.4.0 and cusp 0.2.0
I have problems with compiling the library. I did following steps:
configured pets:
./config/configure.py --with-cc=gcc --with-fc=gfortran
--download-f-blas-lapack=1 --download-mpich=1 --with-cuda=1
--with-debug=no --with-cusp-dir=/usr/local/cuda/include/cusp/
--with-thrust-dir=/usr/local/cuda/include/thrust
then make:
make PETSC_DIR=/home/kuba/External/petsc-dev
PETSC_ARCH=arch-linux-gnu-c-debug all
here I have problems because compilator says that
/usr/local/cuda/include/thrust/iterator/iterator_traits.h:34: fatal
error: iterator: No such file or directory
But actually it is as a symbolic link:
 ls -l /usr/local/cuda/include/
gives
lrwxrwxrwx 1 root root     34 2010-12-09 23:44 thrust
-> /home/kuba/External/thrust/thrust/
and
kuba at desktop:~/External/thrust/thrust/iterator$ ls -l
razem 96
-rw-r--r-- 1 kuba kuba  7666 2010-12-09 21:30 constant_iterator.h
-rw-r--r-- 1 kuba kuba  6959 2010-12-09 21:30 counting_iterator.h
drwxr-xr-x 3 kuba kuba  4096 2010-12-09 21:30 detail
-rw-r--r-- 1 kuba kuba  4376 2010-12-09 21:30 iterator_adaptor.h
-rw-r--r-- 1 kuba kuba  8282 2010-12-09 21:30 iterator_categories.h
-rw-r--r-- 1 kuba kuba 14279 2010-12-09 21:30 iterator_facade.h
-rw-r--r-- 1 kuba kuba  2066 2010-12-09 21:30 iterator_traits.h
-rw-r--r-- 1 kuba kuba  6880 2010-12-09 21:30 permutation_iterator.h
-rw-r--r-- 1 kuba kuba  7055 2010-12-09 21:30 reverse_iterator.h
-rw-r--r-- 1 kuba kuba 10089 2010-12-09 21:30 transform_iterator.h
-rw-r--r-- 1 kuba kuba  7348 2010-12-09 21:30 zip_iterator.h
Have somebody faced this kind of problem?
Here it is compilation log to first error
kuba at desktop:~/External/petsc-dev$ make
See documentation/faq.html and documentation/bugreporting.html
for help with installation problems. Please send EVERYTHING
printed out below when reporting problems
To subscribe to the PETSc announcement list, send mail to
majordomo at mcs.anl.gov with the message:
subscribe petsc-announce
To subscribe to the PETSc users mailing list, send mail to
subscribe petsc-users
On czw, 9 gru 2010, 23:56:38 CET on desktop
Machine characteristics: Linux desktop 2.6.35-22-generic #35-Ubuntu SMP
Sat Oct 16 20:36:48 UTC 2010 i686 GNU/Linux
Using PETSc directory: /home/kuba/External/petsc-dev
Using PETSc arch: arch-linux-gnu-c-debug
PETSC_VERSION_RELEASE    0
PETSC_VERSION_MAJOR      3
PETSC_VERSION_MINOR      1
PETSC_VERSION_SUBMINOR   0
PETSC_VERSION_PATCH      6
PETSC_VERSION_DATE       "Mar, 25, 2010"
PETSC_VERSION_PATCH_DATE "unknown"
PETSC_VERSION_HG         "unknown"
PETSC_VERSION_DATE_HG    "unknown"
PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
Using configure Options: --with-cc=gcc --with-fc=gfortran
Using configuration flags:
#define INCLUDED_PETSCCONF_H
#define IS_COLORING_MAX 65535
#define STDC_HEADERS 1
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_UINTPTR_T uintptr_t
#define PETSC_HAVE_PTHREAD 1
#define PETSC_STATIC_INLINE static inline
#define PETSC_REPLACE_DIR_SEPARATOR '\\'
#define PETSC_RESTRICT  __restrict__
#define PETSC_HAVE_MPI 1
#define PETSC_USE_SINGLE_LIBRARY 1
#define PETSC_USE_SOCKET_VIEWER 1
#define PETSC_HAVE_THRUST 1
#define PETSC_LIB_DIR
"/home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/lib"
#define PETSC_HAVE_FORTRAN 1
#define PETSC_HAVE_SOWING 1
#define PETSC_SLSUFFIX ""
#define PETSC_FUNCTION_NAME_CXX __func__
#define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
#define PETSC_UNUSED
#define PETSC_HAVE_CUDA 1
#define PETSC_FUNCTION_NAME_C __func__
#define PETSC_HAVE_C2HTML 1
#define PETSC_HAVE_VALGRIND 1
#define PETSC_HAVE_BUILTIN_EXPECT 1
#define PETSC_DIR_SEPARATOR '/'
#define PETSC_PATH_SEPARATOR ':'
#define PETSC_HAVE_X11 1
#define PETSC_HAVE_CUSP 1
#define PETSC_Prefetch(a,b,c)
#define PETSC_HAVE_BLASLAPACK 1
#define PETSC_HAVE_STRING_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_ENDIAN_H 1
#define PETSC_HAVE_SYS_PROCFS_H 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_LINUX_KERNEL_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_MATH_H 1
#define PETSC_HAVE_STDLIB_H 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_LIMITS_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_SEARCH_H 1
#define PETSC_HAVE_SYS_SYSINFO_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_HAVE_MEMORY_H 1
#define PETSC_TIME_WITH_SYS_TIME 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_USING_F90 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_C_STATIC_INLINE static inline
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_CXX_NAMESPACE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_C_RESTRICT  __restrict__
#define PETSC_CXX_RESTRICT  __restrict__
#define PETSC_CXX_STATIC_INLINE static inline
#define PETSC_HAVE_LIBCUBLAS 1
#define PETSC_HAVE_LIBCUDART 1
#define PETSC_HAVE_LIBDL 1
#define PETSC_HAVE_LIBFBLAS 1
#define PETSC_HAVE_LIBFLAPACK 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_LIBCUFFT 1
#define PETSC_HAVE_LIBRT 1
#define PETSC_ARCH "arch-linux-gnu-c-debug"
#define PETSC_VERSION_DATE_HG "Thu Dec 09 20:23:16 2010 +0100"
#define PETSC_VERSION_BS_HG "47bec558f992b1828a074066eb6df9f5b106a6b6"
#define PETSC_VERSION_HG "488e1fcaa13db132861c12416293551e6e00b14e"
#define PETSC_DIR "/home/kuba/External/petsc-dev"
#define PETSC_VERSION_BS_DATE_HG "Tue Dec 07 14:41:13 2010 -0600"
#define HAVE_GZIP 1
#define PETSC_CLANGUAGE_C 1
#define PETSC_USE_EXTERN_CXX
#define PETSC_USE_ERRORCHECKING 1
#define PETSC_MISSING_DREAL 1
#define PETSC_SIZEOF_MPI_COMM 4
#define PETSC_BITS_PER_BYTE 8
#define PETSC_SIZEOF_MPI_FINT 4
#define PETSC_SIZEOF_VOID_P 4
#define PETSC_RETSIGTYPE void
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_SIZEOF_LONG 4
#define PETSC_USE_FORTRANKIND 1
#define PETSC_SIZEOF_SIZE_T 4
#define PETSC_SIZEOF_CHAR 1
#define PETSC_SIZEOF_DOUBLE 8
#define PETSC_SIZEOF_FLOAT 4
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_SIGSET 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_TIMES 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_GETPWUID 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_GETTIMEOFDAY 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_MKSTEMP 1
#define PETSC_HAVE_SIGACTION 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_SIGNAL 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_VFPRINTF 1
#define PETSC_HAVE_MEMALIGN 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_SYSINFO 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE__GFORTRAN_IARGC 1
#define PETSC_SIGNAL_CAST
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_VPRINTF 1
#define PETSC_HAVE_BZERO 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#define PETSC_USE_PROC_FOR_SIZE 1
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_HAVE_SHARED_LIBRARIES 1
#define PETSC_MEMALIGN 16
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_GFORTRAN_IARGC 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_HAVE_MPI_COMM_C2F 1
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#define PETSC_HAVE_MPI_COMM_F2C 1
#define PETSC_HAVE_MPI_FINT 1
#define PETSC_HAVE_MPI_F90MODULE 1
#define PETSC_HAVE_MPI_FINALIZED 1
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#define PETSC_HAVE_MPI_WIN_CREATE 1
#define PETSC_HAVE_MPIIO 1
#define PETSC_HAVE_MPI_C_DOUBLE_COMPLEX 1
#define PETSC_HAVE_MPI_ALLTOALLW 1
#define PETSC_HAVE_MPI_IN_PLACE 1
#define PETSC_USE_INFO 1
#define PETSC_PETSC_USE_BACKWARD_LOOP 1
#define PETSC_Alignx(a,b)
#define PETSC_USE_DEBUG 1
#define PETSC_USE_LOG 1
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_USE_CTABLE 1
#define PETSC_USE_GDB_DEBUGGER 1
#define PETSC_CUDA_EXTERN_C_BEGIN extern "C" {
#define PETSC_CUDA_EXTERN_C_END }
#define PETSC_HAVE_CUSP_SMOOTHED_AGGREGATION 1
#define PETSC_BLASLAPACK_UNDERSCORE 1
Using C/C++ include paths: -I/home/kuba/External/petsc-dev/include
-I/home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/include
-I/usr/local/cuda/include -I/usr/local/cuda/include/cusp/
-I/usr/local/cuda/include/thrust/
Using C/C++
compiler: /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/bin/mpicc
-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3
Using Fortran include/module paths:
Using Fortran
compiler: /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/bin/mpif90 -Wall -Wno-unused-variable -g
Using C/C++
linker: /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/bin/mpicc
Using C/C++ flags: -Wall -Wwrite-strings -Wno-strict-aliasing
Using Fortran
linker: /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/bin/mpif90
Using Fortran flags: -Wall -Wno-unused-variable -g
Using libraries:
-L/home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/lib  -lpetsc
-lX11 -Wl,-rpath,/usr/local/cuda/lib -L/usr/local/cuda/lib -lcufft
-lcublas -lcudart
-Wl,-rpath,/home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/lib
-lflapack -lfblas -L/usr/lib/gcc/i686-linux-gnu/4.4.5
-L/usr/lib/i686-linux-gnu -ldl -lmpich -lopa -lmpl -lrt -lpthread
-lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
-lstdc++ -ldl -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
Using
mpiexec: /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/bin/mpiexec
/bin/rm -f
-rf /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/lib/libpetsc*.*
/bin/rm -f
-f /home/kuba/External/petsc-dev/arch-linux-gnu-c-debug/include/petsc*.mod
BEGINNING TO COMPILE LIBRARIES IN ALL DIRECTORIES
libfast in: /home/kuba/External/petsc-dev/src
libfast in: /home/kuba/External/petsc-dev/src/inline
libfast in: /home/kuba/External/petsc-dev/src/sys
libfast in: /home/kuba/External/petsc-dev/src/sys/viewer
libfast in: /home/kuba/External/petsc-dev/src/sys/viewer/impls
libfast in: /home/kuba/External/petsc-dev/src/sys/viewer/impls/socket
In file included from /usr/local/cuda/include/cusp/detail/config.h:24,
                 from /usr/local/cuda/include/cusp/memory.h:20,
from /home/kuba/External/petsc-dev/include/petscsys.h:1671,
                 from send.c:3:
/usr/local/cuda/include/thrust/version.h:69: error: expected ‘=’, ‘,’,
‘;’, ‘asm’ or ‘__attribute__’ before ‘thrust’
In file included from /usr/local/cuda/include/cusp/memory.h:22,
                 from send.c:3:
compilation terminated.
Dnia 2010-12-09, czw o godzinie 20:47 +0100, Jed Brown pisze:
> On Thu, Dec 9, 2010 at 20:44, Jakub Pola <jakub.pola at gmail.com> wrote:
>         Petsc Release Version 3.1.0
> You need petsc-dev for this.
