[petsc-users] MatMAIJ tests
Jed Brown jed at 59A2.org
Tue Dec 7 15:50:57 CST 2010
On Tue, Dec 7, 2010 at 22:45, Nunion <m.skates82 at gmail.com> wrote:
> What would be a fix to get around the issue with complex numbers for  ex100.c:
> Tests vatious routines in MatMAIJ format<http://w3.pppl.gov/m3d/petsc-dev/src/mat/examples/tests/ex100.c.html>in the src/mat/examples/tests/ directory.
> Currently it is not written for complex numbers.
The code in that test would not have to change, but the on-disk binary
format would need to change so that real matrices could be loaded.  Or a
sister file would need to be written that did use complex.  Why do you want
to run this test with complex?
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101207/ea9bc5d8/attachment.htm>
