[petsc-users] Is PCMG a generic PC object ?
Jed Brown jed at 59A2.org
Tue Dec 7 04:07:30 CST 2010
On Tue, Dec 7, 2010 at 07:42, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> When I use PCMG as a preconditioner to solve a fine grid system using
> a linear solver, how do I set the interpolation to the linear system
> being solved. i.e., my preconditioner starts at max_levels and
> hierarchy proceeds to 0 (coarsest) and my linear system is technically
> at max_levels+1.
Set nlevels to whatever you want with PCMGSetLevels, then level=nlevels-1 is
the fine-level problem, you can set the pre-smoother on that level to PCNONE
if you want the "down" part of your cycle to skip it.
> I have a vector length incompatibility since I cannot
> seem to set the prolongation to go from max_levels to max_levels+1,
> where the linear solver subspace resides.
The finest level in PCMG should be the space that your KSP works in.  The
interpolation operator on that level maps from the next coarsest level, i.e.
MatInterpolate(level[n].restrict,level[n-1].x,level[n].x);
> I thought of adding the original fine grid problem to the PCMG levels
> (now max_levels=max_levels+1) but this by philosophy uses PCMG itself
> as a solver. Does it not ?
No, it's still a preconditioner.  "Multigrid as a solver" just means
"Richardson preconditioned by multigrid".
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101207/0b025430/attachment.htm>
