[petsc-users] run direct linear solver in parallel
Fri Dec 3 16:22:24 CST 2010
  You are using an ANCIENT version of PETSc but using documentation from a much newer version. You should upgrade to petsc-3.1 immediately then life will be easy :-)
   Barry
On Dec 3, 2010, at 4:19 PM, Xiangdong Liang wrote:
> Hi everyone,
> I am wondering how I can run the direct solver in parallel. I can run
> my program in a single processor with direct linear solver by
> ./foo.out  -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package spooles
> However, when I try to run it with mpi:
> mpirun.openmpi -np 2 ./foo.out -ksp_type preonly -pc_type lu
> I got error like this:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Matrix type mpiaij  symbolic LU!
> [0]PETSC ERROR: Libraries linked from
> /home/hazelsct/petsc-2.3.3/lib/linux-gnu-c-opt
> [0]PETSC ERROR: Configure run at Mon Jun 30 14:37:52 2008
> [0]PETSC ERROR: Configure options --with-shared --with-dynamic
> --with-debugging=0 --useThreads 0 --with-mpi-dir=/usr/lib/openmpi
> --with-mpi-shared=1 --with-blas-lib=-lblas --with-lapack-lib=-llapack
> --with-umfpack=1 --with-umfpack-include=/usr/include/suitesparse
> --with-umfpack-lib="[/usr/lib/libumfpack.so,/usr/lib/libamd.so]"
> --with-superlu=1 --with-superlu-include=/usr/include/superlu
> --with-superlu-lib=/usr/lib/libsuperlu.so --with-spooles=1
> --with-spooles-include=/usr/include/spooles
> --with-spooles-lib=/usr/lib/libspooles.so --with-hypre=1
> --with-hypre-dir=/usr --with-babel=1 --with-babel-dir=/usr
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatLUFactorSymbolic() line 2174 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCSetUp_LU() line 257 in src/ksp/pc/impls/factor/lu/lu.c
> Would you like to tell me where I am doing wrong? I appreciate your help.
> Xiangdong
