[petsc-users] Is PCMG a generic PC object ?
Jed Brown jed at 59A2.org
Fri Dec 3 13:56:20 CST 2010
On Fri, Dec 3, 2010 at 20:53, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> So this does require the fine grid matrix to be formed explicitly and
> handed over to the top level KSP solver ?
If you want to use Galerkin coarse operators, then you have to assemble the
fine-grid matrix.  This is an algorithmic issue, not a matter of PETSc's API
or something like that.  If you can provide matrix-free residuals/smoothers,
then you don't need to use the Galerkin procedure to build coarse operators.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101203/1b3e1288/attachment.htm>
