[petsc-users] Is PCMG a generic PC object ?
    Jed Brown
    jed at 59A2.org
    Fri Dec  3 13:27:01 CST 2010
On Fri, Dec 3, 2010 at 20:20, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> This is fine and I am more than happy to hand these to Petsc. I do
> have the restriction/prolongation matrices explicitly but only the
> operators are matrix-free for now. So if I start off with a
> matrix-free PC operator, how exactly do I provide the shell matrix
> operators for all the other levels ?
PCMGSetResidual, PCMGGetSmoother and set it to whatever type you want (maybe
your custom one).
> I do not see any routine to enable this and my conclusion is that
> petsc does find it using the fine grid operator at hand using R^T*A*R
> transformation.
Galerkin coarse operators really need to be formed (not applied as a
product) to make sense.  PCMG calls MatPtAP(), Galerkin coarse operators
will not work unless this is implemented.  You want to provide the matrix
yourself.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101203/187882f6/attachment.htm>
