[petsc-users] column index in MatSetValues()
Peter Wang pengxwang at hotmail.com
Thu Dec 2 11:20:36 CST 2010
 I changed the '1' to PetscInt ione, However, the error still comes out.
 do II=Istart,Iend-1
        mone=II+1 !(Coef,snr,rnr are 1-based row and column numbers, shifting them to 0-based)
            write(*,'(1a,4i7)')'II=',II,mone,snr(mone),rnr(mone)
        call MatSetValues(A_Petsc,ione,snr(mone),ione,rnr(mone),Coef(mone),INSERT_VALUES,ierr)  ! PetscInt  ione and mone; PetscInt snr(n_nz),rnr(n_nz) PetscReal Coef(n_nz)
    enddo
BTW, I am running the code on the clusters of supurcomputer. Where the option  ' --with-64-bit-indices=1' shold I find and remove?
!===The modified code is ==
program Debug_PETSc_MatCreate_20101130
implicit none
#include "finclude/petscsys.h"
#include "finclude/petscvec.h"
#include "finclude/petscmat.h"
#include "finclude/petscpc.h"
#include "finclude/petscksp.h"
! Variables
!  PETSc Variables
      real*8  norm
      PetscInt  i,j,II,JJ,its   !,m,n
      PetscInt  Istart,Iend,ione,mone
      PetscErrorCode ierr
      PetscMPIInt     myid,numprocs
      PetscTruth  flg
      PetscScalar v,one,neg_one
      Vec         x,b,u
      Mat         A_petsc
      KSP         ksp
      PetscInt,parameter::n_nz=4
!  Other Variables
PetscInt::snr(n_nz),rnr(n_nz)
!parameter::n_nz=4
PetscReal::Coef(n_nz)
data Coef /1.,   2.,    3. ,  4./
data snr  /0,    1,     2,    3/
data rnr  /0,    1 ,    2,    3/
! Body of Debug_PETSc_MatCreate_20101130
!                 Beginning of program
    call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
    call MPI_Comm_rank(PETSC_COMM_WORLD,myid,ierr)
    call MPI_Comm_size(PETSC_COMM_WORLD,numprocs,ierr)
        write(*,"('snr=',4i4)")snr
        write(*,"('rnr=',4i4)")rnr
    call MatCreate(PETSC_COMM_WORLD,A_Petsc,ierr)
    call MatSetSizes(A_Petsc,PETSC_DECIDE,PETSC_DECIDE,n_nz,n_nz,ierr)    !n_nz-1???
    call MatSetFromOptions(A_Petsc,ierr)
    !    write(*,*)A_petsc
    call MatGetOwnershipRange(A_Petsc,Istart,Iend,ierr)
    write(*,'(1a,1i7,1a,1i7)')  &
            '8.....Check after MatGetOwnershipRange() Istart=',Istart,'  Iend=',Iend
    do II=Istart,Iend-1
    enddo
        write(*,'(1a)')'9.....Check after MatSetValues()'
    call MatAssemblyBegin(A_petsc,MAT_FINAL_ASSEMBLY,ierr)
    call MatAssemblyEnd(A_Petsc,MAT_FINAL_ASSEMBLY,ierr)
        write(*,'(1a)')'10.....Check after MatCreate()'
    call MatView(A_Petsc,PETSC_VIEWER_STDOUT_WORLD,ierr)
!      call KSPDestroy(ksp,ierr)
!      call VecDestroy(u,ierr)
!      call VecDestroy(x,ierr)
!      call VecDestroy(b,ierr)
    call MatDestroy(A_petsc,ierr)
    call PetscFinalize(ierr)
end program Debug_PETSc_MatCreate_20101130
> From: bsmith at mcs.anl.gov
> Date: Wed, 1 Dec 2010 08:06:19 -0600
> To: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] column index in MatSetValues()
> You only need this option if you are solving problems with over 2 billion unknowns! I recommend removing it otherwise, it wastes memory and slows performance slightly.
> > MatSetValues(A_Petsc,1,snr(Ione),1,rnr(Ione),Coef(Ione)
> --with-64-bit-indices means ALL integers passed to PETSc MUST be 64 bit, but here you are passing the integer 1 as a "regular" 32 bit integer. You need to declare it as a PetscInt, for example
> PetscInt mone
> mone = 1
> > MatSetValues(A_Petsc,mone,snr(Ione),mone,rnr(Ione),Coef(Ione)
> but better just build PETSc without the --with-64-bit-indices
> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101202/52e74d14/attachment.htm>
