[petsc-users] column index in MatSetValues()
Wed Dec 1 08:06:19 CST 2010
--with-64-bit-indices=1
  You only need this option if you are solving problems with over 2 billion unknowns! I recommend removing it otherwise, it wastes memory and slows performance slightly.
> MatSetValues(A_Petsc,1,snr(Ione),1,rnr(Ione),Coef(Ione)
  --with-64-bit-indices means ALL integers passed to PETSc MUST be 64 bit, but here you are passing the integer 1 as a "regular" 32 bit integer. You need to declare it as a PetscInt, for example
PetscInt  mone
mone = 1
> MatSetValues(A_Petsc,mone,snr(Ione),mone,rnr(Ione),Coef(Ione)
but better just build PETSc without the --with-64-bit-indices
  Barry
On Nov 30, 2010, at 10:33 PM, Peter Wang wrote:
> I am trying to create a matrix and insert values to it. The martix is supposed to be as following:
> 1   0    0   0
> 0   2    0   0
> 0   0    3   0
> 0   0    0   4
> array  coef[] is the diagonal value of the matrix,
>          snr[] is the index of the row, rnr[] is the index of column.
> However, I always get the wrong results. It shows the Column too large: col 4607182418800017408 max 3!     I cheked the value of rnr[].  The output snr and rnr is correct:
> snr=   0   1   2   3
> rnr=   0   1   2   3
> It seems there is something wrong when MatSetValues() is called. Following is a part of the error information. The information is shown at each loop of  do II=Istart,Iend-1
> The output (if any) follows:
> snr=   0   1   2   3
> rnr=   0   1   2   3
> 8.....Check after MatGetOwnershipRange() Istart=      0  Iend=      4
> II=      0      1      0      0
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Argument out of range!
> [0]PETSC ERROR: Column too large: col 4607182418800017408 max 3!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 5, Mon Sep 27 11:51:54 CDT 2010
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: Debug_PETSc_MatCreate_20101130 on a linux-gnu named compute-1-35.hpc.local.uwm by pwang_a Tue Nov 30 22:27:03 2010
> [0]PETSC ERROR: Libraries linked from /sharedapps/uwm/ceas/gcc-4.4.3/petsc/3.1-p5-v1/lib
> [0]PETSC ERROR: Configure run at Fri Oct  8 12:59:16 2010
> [0]PETSC ERROR: Configure options --prefix=/sharedapps/uwm/ceas/gcc-4.4.3/petsc/3.1-p5-v1 --with-mpi-dir=/sharedapps/uwm/common/gcc-4.4.3/openmpi/1.3.2-v1 --with-blas-lapack-dir=/sharedapps/uwm/ceas/gcc-4.4.3/lapack/3.2.2-v1/lib --with-64-bit-indices=1 --with-64-bit-pointers=1 --with-large-file-io=1 --with-x=0
> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 193 in src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: MatSetValues() line 992 in src/mat/interface/matrix.c
> !The code is as following:
> program Debug_PETSc_MatCreate_20101130
> implicit none
> #include "finclude/petscsys.h"
> #include "finclude/petscvec.h"
> #include "finclude/petscmat.h"
> #include "finclude/petscpc.h"
> #include "finclude/petscksp.h"
> ! Variables
> !  PETSc Variables
>       real*8  norm
>       PetscInt  i,j,II,JJ,its   !,m,n
>       PetscInt  Istart,Iend,ione
>       PetscErrorCode ierr
>       PetscMPIInt     myid,numprocs
>       PetscTruth  flg
>       PetscScalar v,one,neg_one
>       Vec         x,b,u
>       Mat         A_petsc
>       KSP         ksp
>       PetscInt,parameter::    n_nz=4
> !  Other Variables
> !parameter::n_nz=4
> Real*8::Coef(n_nz)
> PetscInt::snr(n_nz),rnr(n_nz)
> data Coef /1.,   2.,    3. ,  4./
> data snr  /0,    1,     2,    3/
> data rnr  /0,    1 ,    2,    3/
> ! Body of Debug_PETSc_MatCreate_20101130
> !                 Beginning of program
>     call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>     call MPI_Comm_rank(PETSC_COMM_WORLD,myid,ierr)
>     call MPI_Comm_size(PETSC_COMM_WORLD,numprocs,ierr)
>         write(*,"('snr=',4i4)")snr
>         write(*,"('rnr=',4i4)")rnr
>     call MatCreate(PETSC_COMM_WORLD,A_Petsc,ierr)
>     call MatSetSizes(A_Petsc,PETSC_DECIDE,PETSC_DECIDE,n_nz,n_nz,ierr)    !n_nz-1???
>     call MatSetFromOptions(A_Petsc,ierr)
>     !    write(*,*)A_petsc
>     call MatGetOwnershipRange(A_Petsc,Istart,Iend,ierr)
>     write(*,'(1a,1i7,1a,1i7)')  &
>             '8.....Check after MatGetOwnershipRange() Istart=',Istart,'  Iend=',Iend
>     do II=Istart,Iend-1
>         ione=II+1 !(Coef,snr,rnr are 1-based row and column numbers, shifting them to 0-based)
>             write(*,'(1a,4i7)')'II=',II,ione,snr(ione),rnr(ione)  !output snr and rnr for error check
>         call MatSetValues(A_Petsc,1,snr(Ione),1,rnr(Ione),Coef(Ione),INSERT_VALUES,ierr)
>     enddo
>         write(*,'(1a)')'9.....Check after MatSetValues()'
>     call MatAssemblyBegin(A_petsc,MAT_FINAL_ASSEMBLY,ierr)
>     call MatAssemblyEnd(A_Petsc,MAT_FINAL_ASSEMBLY,ierr)
>         write(*,'(1a)')'10.....Check after MatCreate()'
>     call MatView(A_Petsc,PETSC_VIEWER_STDOUT_WORLD,ierr)
> !      call KSPDestroy(ksp,ierr)
> !      call VecDestroy(u,ierr)
> !      call VecDestroy(x,ierr)
> !      call VecDestroy(b,ierr)
>     call MatDestroy(A_petsc,ierr)
>     call PetscFinalize(ierr)
> end program Debug_PETSc_MatCreate_20101130
