[petsc-users] Default set of HYPRE's Euclid
Travis Austin austin at txcorp.com
Mon Aug 23 12:18:14 CDT 2010
Liu Lin,
Try to add -pc_hypre_euclid_print_statistics to your command line see if that tells you the default set
that is being used.  For HYPRE's boomeramg a similar command gives you all of the info that you need.
Travis Austin
Travis Austin, Ph.D.
Tech-X Corporation
5621 Arapahoe Ave, Suite A
Boulder, CO 80303
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100823/4d224dd2/attachment.htm>
