[petsc-users] Compile and link correctly using conf/petscvariables and conf/variables
Filippo Spiga
filippo.spiga at disco.unimib.it
Thu Aug 5 14:47:20 CDT 2010
Dear Matthew,
Matthew Knepley wrote:
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> foo: foo.o
> ${CLINKER} -o foo foo.o ${PETSC_TS_LIB}
I already have a Makefile. But most important I have a autoconf script
that generates my configure that generates my Makefile. So I have two
possibilities:
- modify every single Make template to use "conf/variables" and
"conf/rules" as you suggested (long, boring and useless strategy because
all my current Makefiles work. I only want to generalize the configure
as much as possible replacing one single line);
- or starting from "conf/petscvariables" I can try to compose by myself
the only information I need to generalize my scripts.
I only need the name of the library. That's all. Or, if it was compiled
splitting it in different indipendent libraries, I need the right order
to link {PETSC_CONTRIB_BASIC, PETSC_SNES_LIB_BASIC, PETSC_KSP_LIB_BASIC,
PETSC_MAT_LIB_BASIC, PETSC_LIB_BASIC, PETSC_VEC_LIB_BASIC,
PETSC_DM_LIB_BASIC, PETSC_TS_LIB_BASIC, PETSC_SYS_LIB_BASIC}. I don't
understand why "conf/petscvariables" doesn't provide that information. I
guess it's easy to store it in one single explicit line. I'm looking for
a easy way to ensure portability, I don't want to increase the
complexity of the makefile/configure.
If starting from the last stable release PETSc is compiled by default in
one single library (and it is), I can ignore all these stuffs until that
kind of "portability" problem will arise. I will probably do that at
this point...
Thank you very much for your explanations,
Regards
Filippo SPIGA
«Nobody will drive us out of Cantor's paradise.»
-- David Hilbert
