[petsc-users] Problems with preconditioners, which one?
Hong Zhang
hzhang at mcs.anl.gov
Wed Aug 4 10:10:16 CDT 2010
Filippo,
Sorry, your matrix is ill-conditioned, gmres+ilu does not converge in
true residual
(not preconditioned residual!):
./ex10 -f0 $D/A_rhs_spiga -ksp_monitor_true_residual
0 KSP preconditioned resid norm 1.011174511507e+01 true resid norm
2.084628109126e-02 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 1.498441679989e+00 true resid norm
4.919980218651e-02 ||r(i)||/||b|| 2.360123706052e+00
2 KSP preconditioned resid norm 1.657440211742e-01 true resid norm
1.624190902280e-02 ||r(i)||/||b|| 7.791274113447e-01
3 KSP preconditioned resid norm 7.568788163764e-02 true resid norm
1.516900048065e-02 ||r(i)||/||b|| 7.276597880572e-01
4 KSP preconditioned resid norm 3.158616884464e-02 true resid norm
1.703303336172e-02 ||r(i)||/||b|| 8.170777937395e-01
5 KSP preconditioned resid norm 6.169977289081e-08 true resid norm
1.629219484085e-02 ||r(i)||/||b|| 7.815396314348e-01
Using superlu, I get condition number
./ex10 -f0 $D/A_rhs_spiga -pc_type lu -pc_factor_mat_solver_package
superlu -mat_superlu_conditionnumber
Recip. condition number = 1.171784e-04
For such tiny matrix (27x27), condition number=1.e+4.
Using superlu_dist or mumps LU as precondition might be the only
option for your application.
Hong
On Wed, Aug 4, 2010 at 9:53 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Filippo,
> Yes, the matrix is well conditioned.
> Using ~petsc-dev/src/mat/examples/tests/ex78.c, I converted your
> matlab matrix and rhs
> into petsc binary format. Then run it with
> petsc-dev/src/ksp/ksp/examples/tutorials/ex10.c:
> which gives same error on numerical factorization as yours.
> Then switching to superlu and mumps LU direct sovler, I get
> ./ex10 -f0 $D/A_rhs_spiga -pc_type lu -pc_factor_mat_solver_package superlu
> Number of iterations = 1
> Residual norm < 1.e-12
> Using petsc default sovler (gmres+ilu):
> 0 KSP Residual norm 1.011174511507e+01
> 1 KSP Residual norm 1.498441679989e+00
> 2 KSP Residual norm 1.657440211742e-01
> 3 KSP Residual norm 7.568788163764e-02
> 4 KSP Residual norm 3.158616884464e-02
> 5 KSP Residual norm 6.169977289081e-08
> Number of iterations = 5
> Residual norm 0.0162922
> As you see, it converges well.
> For you info., I attached the binary file A_rhs_spiga here.
> Hong
> On Tue, Aug 3, 2010 at 11:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Matt and Hong,
>> The eigenvalues are all nonzero, so I don't see how the matrix could be
>> singular, all the real parts are positive so it is even a nice matrix. But a
>> bunch of diagonal entries are identically zero, this screws up most LU
>> factorization schemes that do not do pivoting. (Matlab does pivoting).
>> 0.0109 + 0.0453i
>> 0.0109 - 0.0453i
>> 0.0071 + 0.0131i
>> 0.0071 - 0.0131i
>> 0.0072 + 0.0121i
>> 0.0072 - 0.0121i
>> 0.0049 + 0.0062i
>> 0.0049 - 0.0062i
>> 0.0059 + 0.0012i
>> 0.0059 - 0.0012i
>> 0.0034 + 0.0031i
>> 0.0034 - 0.0031i
>> 0.0068 + 0.0226i
>> 0.0068 - 0.0226i
>> 0.0061 + 0.0061i
>> 0.0061 - 0.0061i
>> 0.0033 + 0.0028i
>> 0.0033 - 0.0028i
>> 6.0000
>> 8.0000
>> 2.0000
>> 8.0000
>> 12.0000
>> 4.0000
>> 2.0000
>> 4.0000
>> 2.0000
>> On Aug 3, 2010, at 11:03 PM, Matthew Knepley wrote:
>> On Tue, Aug 3, 2010 at 10:54 PM, Filippo Spiga
>> <filippo.spiga at disco.unimib.it> wrote:
>>> Dear Hong,
>>>> This confirms that your Jacobian is singular, thus none of linear
>>>> solvers would work.
>>> So do any preconditioner not help me to solve the problem?
>> There can exist no solutions when the matrix is singular, thus you have a
>> problem
>> with either:
>> a) the problem definition
>> b) the creation of your matrix in PETSc
>>> I put some stuff here: http://tinyurl.com/fil-petsc
>>> - "A_LS.m" is matrix (saved by PETSc)
>>> - "b_LS-m"
>>> - the file "eigenvalues_A" contains the eigenvalues of the matrix A,
>>> computed by MATLAB.
>>> I used "-pc_type lu" and 1 only processor. The result is the same of my
>>> previous email (*).
>> This shows that your matrix is singular.
>>> Anyway if I solve the problem using MATLAB I get the right solution. The
>>> formulation seems correct. To be
>> What does this mean? What method in MATLAB? Some methods (like CG) can
>> iterate on rank deficient
>> matrices with a compatible rhs and get a solution, but other Krylov methods
>> will fail. Most preconditioners
>> will fail.
>>> honest, the eigenvalues don't say me nothing. But I'm a computer
>>> scientist, not a mathematician. I'm not able to recognize which
>>> preconditioner I should use or which modifications (scaling all/part of the
>>> rows? reformulate the system in another way?...) do to solve the problem.
>>> From my side, it is not possible to try all the preconditioners and also it
>>> is not the right way...
>> Actually, I strongly disagree. Preconditioners are very problem specific,
>> and it is often impossible
>> to prove which one will work for a certain problem. There are many
>> well-known results along these
>> lines, such as the paper of Greenbaum, Strakos, and Ptak on GMRES.
>> Experimentation is essential.
>> Matt
>>> Once again, thanks.
>>> [0|23:14:58]: unknown: MatLUFactorNumeric_SeqAIJ() line 668 in
>>> src/mat/impls/aij/seq/aijfact.c: Zero pivot row 1 value 0 tolerance
>>> 2.77778e-14 * rowsum 0.0277778
>>> Filippo SPIGA
>>> «Nobody will drive us out of Cantor's paradise.»
>>> -- David Hilbert
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
