[petsc-users] about FD Jacobian  for the new DAE solver
    Li, Zhisong (lizs)
    lizs at mail.uc.edu
    Thu Apr 29 16:08:38 CDT 2010
Last time I was suggested by Jed using the DAE solver to build my nonlinear CFD code based on TS. For incompressible N-S equations, I think it's difficult to derive the analytical Jacobian formulation, and we need a finite difference approximation or matrix-free method.
What I previously done was integrating the incompressible N-S equations into tutorial code ts/ex7.c  . It simply uses an argument "TSDefaultComputeJacobianColor" to finish the Jacobian issue. When I switch to TSSetIFunction() and TSSetIJacobian(), this argument doesn't work anymore. And if I remove all Jacobian-related lines and use -snes_mf command option, it prompts out error message "Must Set Jacobian!". Do you know how to resolve this for both methods?
Thank you.
Zhisong Li
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100429/9ca0bccf/attachment.htm>
