[petsc-users] Newbie Question - Really slow - PetscMemCpy
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Apr 22 07:59:17 CDT 2010
On Apr 22, 2010, at 7:33 AM, Parker, Andrew (UK Filton) wrote:
> Hi,
> I'm new to these postings.  On very large cases, regardless of where
> I stop the debugger it is always copying data.  I've put it into a
> debugger because on smaller cases it runs fine, on larger it takes a
> while (very long time) to get going.  The stack trace always gives
> something like:
> memcpy
> PetscMemCpy
> MatSetValues_SeqAIJ
     It is using SeqAIJ matrices
> MatSetValues
> my own wrapper to add values to a location within the matrix.
> I'm using Seq_BAIJ.  My bets are that I've got the sparsity wrong,
> or the preallocation wrong, but I'm not sure why.  I know this could
> be anything, but has anybody got any thoughts, remember stopping the
> debugger at random, regardless of the frequency always gives the
> above....
> I set up the matrix like this
>   MatCreate(PETSC_COMM_SELF,&_storage);
> MatSetSizes
> (_storage,PETSC_DECIDE,PETSC_DECIDE,numVars*numLocs,numVars*numLocs);
>   MatSetFromOptions(_storage);
> MatSeqBAIJSetPreallocation(_storage,numVars,PETSC_NULL,sparsityStart);
     Unless you use the argument -mat_type seqbaij this will use
SeqAIJ while you preallocate SeqBAIJ.
> However, using this makes zero difference to the speed
>    MatCreateSeqBAIJ(PETSC_COMM_SELF,
>       numVars,
>       numVars*numLocs,
>       numVars*numLocs,
>       0,
>        sparsityStart,
>       &_storage);
> It is so slow that it has not even completed one cycle of the
> solver....
     Your sparseityStart is wrong. Run with -info and grep the results
for malloc and you'll see it is mallocing many times to get enough
space.
    Barry
> Cheers again,
> Andy
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100422/bcdd5115/attachment.htm>
