[petsc-users] zero diagonals
Barry Smith
bsmith at mcs.anl.gov
Mon Apr 19 16:08:34 CDT 2010
-pc_factor_mat_shift_type nonzero or -sub_pc_factor_shift_type
nonzero or -mg_coarse_pc_factor_shift_type nonzero depending on where
it is used.
You can always run with -help and grep for shift_type to find out
which one is needed
Barry
On Apr 19, 2010, at 4:04 PM, hxie at umn.edu wrote:
> Hi,
> I have a matrix with some zero diagonals. Now I create a new matrix
> for preconditioner and use Matshift to avoid the zero diagonals in
> the preconditioner matrix. It works fine. Is that possible to just
> use the command line options? If I just want to shift the zero
> diagonals, how can I do that? Thanks.
> Bests,
> Hui
