[petsc-users] glibc detected
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Sat Apr 17 10:07:55 CDT 2010
Dear Jed,
What did I do wrong on this? Nothing comes out from -malloc 0:
rebecca at YuanWork:~/linux/code/twoway/twoway_new/workingspace$ valgrind
-malloc 0 ./twgcqt2unffnictvscj.exe -options_file option_all
valgrind: 0: command not found
--malloc 0 ./twgcqt2unffnictvscj.exe -options_file option_all
Thanks a lot!
Rebecca
Quoting Jed Brown <jed at 59A2.org>:
> On Sat, 17 Apr 2010 10:10:00 -0400, "(Rebecca) Xuefei YUAN"
> <xy2102 at columbia.edu> wrote:
>> Dear Matt,
>> I did run with valgrind, and the error message is for a
>> DAGetLocalVector() in FormFunction() which is not related to this
>> structure.
> This first error is causing memory corruption which causes the invalid
> free() you see later.  Run with valgrind and -malloc 0, then fix every
> item in the order they appear (many of the later items will be caused by
> earlier corruption, so rerun valgrind after each fix).
> Jed
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
