[petsc-users] about Vecgetarray()
Satish Balay
balay at mcs.anl.gov
Sat Apr 17 10:00:11 CDT 2010
> On Fri, 16 Apr 2010, 陈乐平(Leping Chen) wrote:
> > PetscOffset xx_i
> > Vec x
> > double precision u(6)
> > call VecGetArray(x,u,xx_i,ierr)
> > do 30 i=1,n
> > u(i) = 1000.0*i
> u(i+xx_i) = 1000.0*i
> > 30 continue
> > call VecRestoreArray(x,u,xx_i,ierr)
Hopefully the following clears up the confusion.
You are expecting the following to work:
integer n=6
call VecGetArray(x,u,ierr)
do 30 i=1,n
u(i) = 1000.0*i
30 continue
call VecRestoreArray(x,u,ierr)
Here you are expecting VecGetArray to *copy* the values of 'x' into
'u'. And VecRestoreArray() to *copy* values from 'u' to 'x'. However
these copies are inefficient - so we do not do that.
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-3.1/docs/manualpages/Vec/VecGetArray.html
Here VecGetArray() tries to return the *pointer* to the array stored
in the Vec. This is possible in C - but not fortran77. Hence the concept
of using offset in the f77 interface.
Note: the above is out-of-bounds access of 'u' wrt F77 - and it is a
workarround against the limitation of F77 language. [so its not pure
F77 code].
So if you need pure language compliant code - check VecGetArrayF90()
as indicated before. It returns a F90 pointer from a Vec.
Satish
