[petsc-users] ML and -pc_factor_shift_nonzero
Tue Apr 13 10:08:13 CDT 2010
   -mg_coarse_pc_factor_shift_nonzero since it is the coarse level of
the multigrid that is producing the zero pivot.
    Barry
On Apr 13, 2010, at 8:51 AM, Matthew Knepley wrote:
> On Tue, Apr 13, 2010 at 2:49 PM, <tribur at vision.ee.ethz.ch> wrote:
> Hi,
> using ML I got the error
> "[0]PETSC ERROR: Detected zero pivot in LU factorization"
> As recommended at http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> , I tried -pc_factor_shift_nonzero but it doesn't have the desired
> effect using ML.
> How do I have to formulate the command line option? What does -
> [level]_pc_factor_shift_nonzero mean? What other parallel
> preconditioner could I try besides Hypre/Boomeramg or ML?
> This means the MG level, like 2. You can see all available options
> using -help.
>   Matt
> Thanks in advance for your precious help,
> Kathrin
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100413/281ecff3/attachment.htm>
