cannot convert '_p_Vec* const' to '_p_VecScatter*' for argument '1' to 'PetscErrorCode
Anirban Chatterjee
achatter at cse.psu.edu
Tue Nov 24 09:43:43 CST 2009
Hi Satish,
Yes, that fixes it. I can install OOQP with petsc-2.3.0 without a problem.
But after fixing the VecScatter problem if I try petsc-3.0 then I end up
in a linker error in src/QpBound/QpBoundPetsc.o
"undefined reference to PetscIterativeSolver::PetscIterativeSolver". I
cannot understand this. I have to check this.
--Anirban
Satish Balay wrote:
> I guess OOQP is not updated to use the latest petsc version - where
> the first argument is VecScatter.
> Is this the only error you get? If so - its easy to just fix the code
> to use petsc-3
> VecScatterBegin(Vec,Vec,InsertMode,ScatterMode,VecScatter);
> changed to:
> VecScatterBegin(VecScatter,Vec,Vec,InsertMode,ScatterMode);
> Satish
> On Tue, 24 Nov 2009, Anirban Chatterjee wrote:
>> Hi,
>> I am trying to use Steve Wright's OOQP with PETSc support and get this error:
>> cannot convert '/_p_Vec/* const' to '/_p_VecScatter/*' for argument '1' to
>> 'PetscErrorCode
>> Can anyone tell me why I am getting this error. I am getting this error in the
>> VecScatterBegin function where the first argument type is Vec.
>> Thanks,
>> Anirban
