Petsc parallel vectors with two communicators
Khan, Irfan irfan.khan at gatech.edu
Wed Mar 25 10:45:50 CDT 2009
Thanks Matt. That helped a lot. Things seem to be working now.
Regards
Irfan
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Wednesday, March 25, 2009 9:08:24 AM GMT -05:00 US/Canada Eastern
Subject: Re: Petsc parallel vectors with two communicators
On Wed, Mar 25, 2009 at 1:05 AM, Khan, Irfan < irfan.khan at gatech.edu > wrote:
Hi
Can the petsc parallel vectors be used with two different communicators? For instance, I have created two different communicators called FEA_Comm and FSI_Comm. The total number of processes are x+y. FSI_Comm works on x+y but FEA_Comm works only on x.
Now I am trying to create parallel vectors a1 and a2 such that a1 has entries from x+y processes but a2 has entries from only y processes.
After splitting the communicators I assign PETSC_COMM_WORLD to FEA_Comm which works on only x processes. Subsequently petsc is initialized (PetscInitialize()). But when the parallel vectors are created, the processes hang.
PETSC_COMM_WORLD should encompass all processes you wish to use in PETSc, so that means x+y. You can create Vec
objects on subcommunicators, like x.
Matt
Any suggestions will be helpful
Thankyou
Irfan
Graduate Research Assistant
Woodruff school of Mechanical Engineering
Atlanta, GA (30307)
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090325/f27a8893/attachment-0001.htm>
