PCNN preconditioner and setting the interface
Andreas Grassl
Andreas.Grassl at student.uibk.ac.at
Tue Mar 24 08:45:27 CDT 2009
Hello,
I'm working with a FE-Software where I get out the element stiffness
matrices and the element-node correspondency to setup the stiffness
matrix for solving with PETSc.
I'm currently fighting with the interface definition. My
LocalToGlobalMapping for test-purposes was the "identity"-IS, but I
guess this is far from the optimum, because nowhere is defined a node
set of interface nodes.
How do I declare the interface? Is it simply a reordering of the nodes,
the inner nodes are numbered first and the interface nodes last?
Thank you in advance
ando
/"\ Grassl Andreas
\ / ASCII Ribbon Campaign Uni Innsbruck Institut f. Mathematik
X against HTML email Technikerstr. 13 Zi 709
/ \ +43 (0)512 507 6091
