matrix assembling time
Ravi Kannan rxk at cfdrc.com
Tue Mar 17 13:15:36 CDT 2009
  -----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov]On Behalf Of Matthew Knepley
  Sent: Tuesday, March 17, 2009 9:47 AM
  To: PETSc users list
  Subject: Re: matrix assembling time
  On Tue, Mar 17, 2009 at 11:41 AM, Ravi Kannan <rxk at cfdrc.com> wrote:
    Hi Barry and others
    For the iterative solver, you mentioned there is much less to gain by
    reording.
    However, you also said we should have a reasonable ordering before
    generating the linear system.
    Suppose I already have already assembled a large system in parallel
(with
    bad bandwidth),
    will reordering the system help to solve the system or not?
  Possibly. However, why would you do that?
    Do we have to do this before the assembling to PETSs solver?
  Not sure what you mean here. You can compute an ordering at any time.
    In this case, I think we will need to renumbering all the nodes and/or
    cells, not only processor-wise but globally considering the ghost cells.
    Is there alternative way such as explicit asking PETSc to reordering the
    assembled linear system?
  I do not see what you are asking here.
    Matt
    Thank you.
    Ravi
    [mailto:petsc-users-bounces at mcs.anl.gov]On Behalf Of Barry Smith
    Sent: Friday, March 13, 2009 6:55 PM
    On Mar 13, 2009, at 12:48 PM, Ravi Kannan wrote:
    > Hi,
    >    This is Ravi Kannan from CFD Research Corporation. One basic
    > question on
    > the ordering of linear solvers in PETSc: If my A matrix (in AX=B) is a
    > sparse matrix and the bandwidth of A (i.e. the distance between non
    > zero
    > elements) is high, does PETSc reorder the matrix/matrix-equations so
    > as to
    > solve more efficiently.
         Depends on what you mean. All the direct solvers use reorderings
    automatically
    to reduce fill and hence limit memory and flop usage.
         The iterative solvers do not. There is much less to gain by
    reordering for iterative
    solvers (no memory gain and only a relatively smallish improved cache
    gain).
       The "PETSc approach" is that one does the following
    1) partitions the grid across processors (using a mesh partitioner)
    and then
    2) numbers the grid on each process in a reasonable ordering
    BEFORE generating the linear system. Thus the sparse matrix
    automatically gets
    a good layout from the layout of the grid. So if you do 1) and 2) then
    no additional
    reordering is needed.
       Barry
experiments lead.
  -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090317/4900832a/attachment.htm>
