matrix assembling time
Ravi Kannan
rxk at cfdrc.com
Fri Mar 13 16:39:25 CDT 2009
Hi Matt
Are you suggesting to use MatGetOrdering()?
Will it work for parallel matrix?
Thanks.
Ravi
-----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov]On Behalf Of Matthew Knepley
Sent: Friday, March 13, 2009 11:34 AM
To: PETSc users list
Subject: Re: matrix assembling time
On Fri, Mar 13, 2009 at 12:48 PM, Ravi Kannan <rxk at cfdrc.com> wrote:
This is Ravi Kannan from CFD Research Corporation. One basic question
on
the ordering of linear solvers in PETSc: If my A matrix (in AX=B) is a
sparse matrix and the bandwidth of A (i.e. the distance between non zero
elements) is high, does PETSc reorder the matrix/matrix-equations so as
to
solve more efficiently. If yes, is there any specific command to do the
above?
You can reorder the matrix using the MatOrdering class.
Matt
Thanks
Ravi
[mailto:petsc-users-bounces at mcs.anl.gov]On Behalf Of Yixun Liu
Sent: Friday, March 06, 2009 12:50 PM
To: PETSC
Subject: matrix assembling time
Using PETSc the assembling time for a mesh with 6000 vertices is about
14 second parallelized on 4 processors, but another sequential program
based on gmm lib is about 0.6 second. PETSc's solver is much faster than
gmm, but I don't know why its assembling is so slow although I have
preallocate an enough space for the matrix.
MatMPIAIJSetPreallocation(sparseMeshMechanicalStiffnessMatrix, 1000,
PETSC_NULL, 1000, PETSC_NULL);
Yixun
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090313/494389b6/attachment.htm>
