Mumps, BoomerAMG, or Pestc?
REN
renzhengyong at gmail.com
Fri Mar 13 09:02:46 CDT 2009
Hi, Matthew and Hong,
I will use PETSc for my 4 years project. :)
Thanks
Zhengyong Ren
On Fri, 2009-03-13 at 08:46 -0500, Hong Zhang wrote:
> Zhengyong,
> > I known your excellent codes several months ago. I want to use Mumps as
> > direct solver for multi-sources problem and BoomerAMG for real-value based
> > iterative solver. I went though the doc of the petsc. It showed that petsc
> > offered a easy and top interface to these two packages. So, I think if I
> > chose the petsc as my tools, the coding work should be easier for me as only
> > data structure of petsc should be leaned, not one for Mumps and one for
> > Hypre.
> > Am I right? can pestc do the work Mumps and BloomAMG do? I want to get your
> Yes, you can use Mumps, BloomAMG and other packages
> (see http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/external.html)
> without changing your application code.
> > confirm on my decision. As you said, sometimes it is important to make a
> > correct decision and also to learn petsc should not be a short way. If petsc
> > really do the fast direct solving and fast algebra multigrid algorithms by
> > Mumps and BloomAMG, respectively, I think PESTC should definitely be the
> > first choice for my following PhD project.
> Here is how to get started:
> 1. install petsc with configure options
> '--download-scalapack --download-superlu --download-superlu_dist
> --download-mumps --download-blacs --download-hypre'
> (you need F90 compiler for mumps. Mumps requires
> scalapack and blacs. I also suggest you install
> superlu and superlu_dist - commonly used sparse direct sovlers)
> 2. build petsc and test the installation
> 3. test mumps and hypre, e.g.,
> cd ~petsc/src/ksp/ksp/examples/tutorials
> make ex2
> ./ex2 -ksp_monitor -ksp_type preonly -pc_type lu
> -pc_factor_mat_solver_package mumps
> Norm of error < 1.e-12 iterations 1
> ./ex2 -ksp_monitor -pc_type hypre -pc_hypre_type boomeramg
> 0 KSP Residual norm 7.372609060992e+00
> 1 KSP Residual norm 5.824128070306e-02
> 2 KSP Residual norm 8.370364383637e-05
> Norm of error 8.39541e-05 iterations 2
> Let us know if you encounter difficulty,
> Hong
> > Zhengyong Ren
> > AUG Group, Institute of Geophysics
> > Department of Geoscience
> > NO H 47 Sonneggstrasse 5
> > CH-8092, Zrich, Switzerland
> > Tel: +41 44 633 37561
> > e-mail: renzh at ethz.ch
> > Gmail: renzhengyong at gmail.com
