multiple rhs
David Fuentes fuentesdt at gmail.com
Thu Mar 12 09:17:46 CDT 2009
Thanks Hong,
The complete error message is attached. I think I just had too big
of a matrix. The matrix i'm trying to factor is 327680 x 327680
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Out of memory. This could be due to allocating
[0]PETSC ERROR: too large an object or bleeding by not properly
[0]PETSC ERROR: destroying unneeded objects.
[0]PETSC ERROR: Memory allocated 2047323584 Memory used by process
2074058752
[0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[0]PETSC ERROR: Memory requested 1258466480!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 2, Wed Jan 14 22:57:05
CST 2009
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./RealTimeImaging on a gcc-4.1.2 named DIPWS019 by
dfuentes Wed Mar 11 20:30:37 2009
[0]PETSC ERROR: Libraries linked from
/usr/local/petsc/petsc-3.0.0-p2/gcc-4.1.2-mpich2-1.0.7-dbg/lib
[0]PETSC ERROR: Configure run at Sat Jan 31 06:53:09 2009
[0]PETSC ERROR: Configure options --download-f-blas-lapack=ifneeded
--with-mpi-dir=/usr/local --with-matlab=1 --with-matlab-engine=1
--with-matlab-dir=/usr/local/matlab2007a --CFLAGS=-fPIC --with-shared=0
[0]PETSC ERROR:
[0]PETSC ERROR: PetscMallocAlign() line 61 in src/sys/memory/mal.c
[0]PETSC ERROR: PetscTrMallocDefault() line 194 in src/sys/memory/mtr.c
[0]PETSC ERROR: PetscFreeSpaceGet() line 14 in src/mat/utils/freespace.c
[0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 381 in
src/mat/impls/aij/seq/aijfact.c
[0]PETSC ERROR: MatLUFactorSymbolic() line 2289 in
src/mat/interface/matrix.c
[0]PETSC ERROR: KalmanFilter::DirectStateUpdate() line 456 in
unknowndirectory/src/KalmanFilter.cxx
[0]PETSC ERROR: GeneratePRFTmap() line 182 in
unknowndirectory/src/MainDriver.cxx
[0]PETSC ERROR: main() line 90 in unknowndirectory/src/MainDriver.cxx
application called MPI_Abort(MPI_COMM_WORLD, 55) - process 0[unset]:
aborting job:
On Thu, 12 Mar 2009, Hong Zhang wrote:
> David,
> I do not see any problem with the calling sequence.
> The memory is determined in MatLUFactorSymbolic().
> Does your code crashes within MatLUFactorSymbolic()?
> Please send us complete error message.
> Hong
> On Wed, 11 Mar 2009, David Fuentes wrote:
>> Hello,
>> I have a sparse matrix, A, with which I want to solve multiple right hand
>> sides
>> with a direct solver.  Is this the correct call sequence ?
>>  MatGetFactor(A,MAT_SOLVER_PETSC,MAT_FACTOR_LU,&Afact);
>>  IS isrow,iscol;
>>  MatGetOrdering(A,MATORDERING_ND,&isrow,&iscol);
>>  MatLUFactorSymbolic(Afact,A,isrow,iscol,&info);
>>  MatLUFactorNumeric(Afact,A,&info);
>>  MatMatSolve(Afact,B,X);
>> my solve keeps running out of memory
>> "[0]PETSC ERROR: Memory requested xxx!"
>> is this in bytes? I can't tell if the problem I'm trying to solve
>> is too large form my machine or if I just have bug in the call sequence.
>> thank you,
>> David Fuentes
