Hello for compiled problem
Wei-Dong Lian weidong.lian at gmail.com
Tue Mar 10 18:38:54 CDT 2009
[--with-shared=0, and do not use --with-dyanmic]
I compiled petsc and link the static lib with my makefile
"ADDLIBSTATIC := $(ADDLIBSTATIC) $(PETSC_LIBDIR)/ libpetsccontrib.a
$(PETSC_LIBDIR)/libpetscksp.a $(PETSC_LIBDIR)/libpetscsnes.a
$(PETSC_LIBDIR)/libpetscvec.a $(PETSC_LIBDIR)/libpetsc.a
$(PETSC_LIBDIR)/libpetscdm.a $(PETSC_LIBDIR)/libpetscmat.a
$(PETSC_LIBDIR)/libpetscts.a"
The result was the same as before. So I really wonder how to link petsc with
static library? This is useful when I could not generate shared library.
Tomorrow morning I will try the  *setCompilers.py *that you sent me for
avoiding the error of -PIC. it is 00:37, I will go to sleep.
See you tomorrow. Good night.
yours sincerely
Weidong
On Tue, Mar 10, 2009 at 10:53 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 10 Mar 2009, Wei-Dong Lian wrote:
> > Now I also found a problem for my computer about using petsc.
> > In my computer, petsc can be compiled successfully without any problem.
> So I
> > use the *.so library to link into my programme, it worked very well. But
> > today I just have a try to link *.a library into my programme and it can
> not
> > be compiled successfully.
> Why do you want to do this? [When shared libraries exist - the
> compiler prefers then - instead of static. So you should just stick
> with the compiler default behavior. And if build PETSc with
> --with-dynamic - then the .a files are useless anyway.]
> So the shared vs static usage should be chosen at PETSc configure step.
> [--with-shared=1/0, and do not use --with-dyanmic]
> So  you should just use:
> ADDLIB := $(ADDLIB) -L$(PETSC_LIBDIR) -Wl,-rpath,$(PETSC_LIBDIR)
> -lpetsccontrib -lpetscts -lpetscsnes -lpetscksp -lpetscdm
> -lpetscmat -lpetscvec -lpetsc
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090311/5063a293/attachment.htm>
