Hello for compiled problem
Tue Mar 10 14:45:14 CDT 2009
On Tue, 10 Mar 2009, Wei-Dong Lian wrote:
> Hello,
> I did not configure the flag -PIC, can you tell me how to change the -PIC to
> -fPIC.
Its a problem with configure - and you default language of choice. Try
changing your lang to english - when building PETSc.
Perhaps the following might work.
export LANG en_US.UTF-8
./config/configure.py ...
make
> By the way, why there are two types lib *.so and *.lib in the library path.
Perhaps you mean .a - not .lib
If you use --with-shared=1 or --with-dynamic=1 - you get .so files aswell.
> But when I change option to FC=g77, it only left *.lib in the library path.
Due to the -PIC issue - perhaps .so files didn't get created..
Satish
