Hello for compiled problem
Tue Mar 10 12:22:26 CDT 2009
On Tue, Mar 10, 2009 at 11:34 AM, Wei-Dong Lian <weidong.lian at gmail.com>wrote:
> Hi,
> I did not use the PETSc makefiles. First I do not know where it located.
> Second, I have configured my makefile to link my programme, before it
> worked, that's in another computer, the difference lies in the fact that
> this time in the lib directory, there were not *.so library, but *.lib
> library. Maybe I think it is the problem.
We CANNOT help you unless you send the logs I asked for in my last message.
Send them to petsc-maint at mcs.anl.gov.
  Matt
> Thanks.
> Weidong
> On Tue, Mar 10, 2009 at 5:07 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Mar 10, 2009 at 10:59 AM, Wei-Dong Lian <weidong.lian at gmail.com>wrote:
>>> Hello everyone,
>>> I compiled the petsc-3.0.0-p3 with GCC 3.4.3 under linux 64. But the
>>> compiler gave me the following information, see result_1.
>>> I also ran the "make test" and it worked successfully, but when I linked
>>> petsc to compile my programme, it told me that information see results_2.
>>> Any suggestion will be appreciated.
>>> Thank you in advance.
>> 1) Any report like this should be sent to petsc-maint at mcs.anl.gov because
>> we need configure.log and make*.log.
>> 2) The warning about -PIC comes about because we cannot parse the warning
>> messages from your compiler. We can try to
>>      add this in when we get the log.
>> 3) If 'make test' works and your link does not, then you have constructed
>> your link line incorrectly. Are you using the PETSc makefiles?
>>   Matt
>>> Weidong
>>> $$$$$$$$$$$$$$$$$$$$$Result_1$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
>>> /ftn-custom
>>> g++: option « -PIC » non reconnue
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/euler
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/rk
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/rk/ftn-auto
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit/beuler
>>> libfast in:
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit/cn
>>> #####################################results_2################################
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2aaf):
>>> In function `DAGetWireBasketInterpolation(_p_DA*, _p_Mat*, MatReuse,
>>> _p_Mat**)':
>>> /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:201:
>>> undefined reference to `PetscTableCreate(int, _n_PetscTable**)'
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2b3d):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:203:
>>> undefined reference to `PetscTableAddCount(_n_PetscTable*, int)'
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2ba1):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:205:
>>> undefined reference to `PetscTableGetCount(_n_PetscTable*, int*)'
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2d24):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:209:
>>> undefined reference to `PetscTableFind(_n_PetscTable*, int, int*)'
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2d8d):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:212:
>>> undefined reference to `PetscTableDestroy(_n_PetscTable*)'
>>> /usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x5adf):
>>> In function `DAGetFaceInterpolation(_p_DA*, _p_Mat*, MatReuse, _p_Mat**)':
>>> My configuration of petsc:
>>>                             Pushing language C
>>>                             Popping language C
>>>                             Pushing language Cxx
>>>                             Popping language Cxx
>>>                             Pushing language FC
>>>                             Popping language FC
>>> sh: /bin/sh
>>> /usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/BuildSystem/config/packages/config.gue
>>> ss
>>> Executing: /bin/sh
>>> fig.guess
>>> sh: x86_64-unknown-linux-gnu
>>> sh: /bin/sh
>>> /usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/BuildSystem/config/packages/config.sub
>>> Executing: /bin/sh
>>> fig.sub x86_64-unknown-linux-gnu
>>> Starting Configure Run at Tue Mar 10 16:23:30 2009
>>> Configure Options: --configModules=PETSc.Configure
>>> --optionsModule=PETSc.compilerOptions --with-cc=gcc --with-fc=g77 --with-cx
>>> x=g++ --with-mpi=0 --with-x=0 --with-clanguage=cxx --with-shared=1
>>> --with-dynamic=1
>>> Working directory:
>>> Machine uname:
>>> ('Linux', 'frioul', '2.6.9-22.ELsmp', '#1 SMP Sat Oct 8 21:32:36 BST
>>> 2005', 'x86_64')
>>> Python version:
>>> 2.3.4 (#1, Feb 17 2005, 21:01:10)
>>> [GCC 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)]
>>>         Pushing language C
>>>         Popping language C
>>>         Pushing language FC
>>>         Popping language FC
>>> TEST configureExternalPackagesDir from
>>> config.framework(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/c
>>> onfig/BuildSystem/config/framework.py:815)
>>> TESTING: configureExternalPackagesDir from
>>> config.framework(config/BuildSystem/config/framework.py:815)
>>> TEST configureLibrary from
>>> PETSc.packages.NetCDF(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/P
>>> ETSc/packages/NetCDF.py:10)
>>> TESTING: configureLibrary from
>>> PETSc.packages.NetCDF(config/PETSc/packages/NetCDF.py:10)
>>>   Find a NetCDF installation and check if it can work with PETSc
>>> PETSc.packages.PVODE(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/PE
>>> TSc/packages/PVODE.py:10)
>>> PETSc.packages.PVODE(config/PETSc/packages/PVODE.py:10)
>>>   Find a PVODE installation and check if it can work with PETSc
>>> TEST configureDebuggers from
>>> PETSc.utilities.debuggers(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/co
>>> nfig/PETSc/utilities/debuggers.py:22)
>>> TESTING: configureDebuggers from
>>> PETSc.utilities.debuggers(config/PETSc/utilities/debuggers.py:22)
>>>   Find a default debugger and determine its arguments
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090310/00a9362b/attachment.htm>
