Solver problem
Tim Kroeger tim.kroeger at cevis.uni-bremen.de
Thu Jul 30 04:52:28 CDT 2009
Dear Matt,
On Wed, 29 Jul 2009, Matthew Knepley wrote:
> On Wed, Jul 29, 2009 at 8:49 AM, Tim Kroeger <tim.kroeger at cevis.uni-bremen.de> wrote:
>> It seems as if I can't use MUMPS since the cluster I am working on doesn't
>> meet some system requirements.  (PETSc otherwise works fine on the cluster.)
>>  However, I understand that PETSc also interfaces a large number of other
>> sparse direct solvers.  Are there any recommendations about which one might
>> be a good choice if MUMPS cannot be used?
> You can try SuperLU_dist.
Thank you very much.  SuperLU_Dist works great!
Best Regards,
Tim
Dr. Tim Kroeger
tim.kroeger at mevis.fraunhofer.de            Phone +49-421-218-7710
tim.kroeger at cevis.uni-bremen.de            Fax   +49-421-218-4236
Fraunhofer MEVIS, Institute for Medical Image Computing
Universitaetsallee 29, 28359 Bremen, Germany
