suggestions for debugging code
Randall Mackie
rlmackie862 at gmail.com
Wed Jul 29 11:36:07 CDT 2009
Matthew,
Thanks - it took me the better part of the day yesterday to get the suppression
file so that it cut out most of the MPI stuff, and then I was able to eventually
zero in and find the offending bug.
Randy
Matthew Knepley wrote:
> On Tue, Jul 28, 2009 at 10:17 AM, Randall Mackie <rlmackie862 at gmail.com
> <mailto:rlmackie862 at gmail.com>> wrote:
> I have run into a very difficult debugging problem. I have recently
> made some
> modifications to my PETSc code, to add some new features. When I
> compiled the
> code in debug mode (we are using the Intel compilers and mvapich on
> Infiniband),
> the code runs fine with any number of processes.
> When the code is compiled in optimize mode, it runs fine on, say, up
> to 32 processes,
> but not 64, bombing out someplace strange, with a Segmentation
> Violation.
> I've tried using Valgrind, but you can't use it with PETSc and my
> code compiled in
> Debug mode because the code finishes successfully, and the other
> problem I have with
> Sometimes valgrind will catch things even when code does not crash.
> Valgrind + mvapich is there are about a million messages spewed out,
> making it
> extremely difficult to see if there are really any issues in MY
> code. I've thought
> to have PETSc download and compile MPICH2, which I would hope would
> produce less
> output from Valgrind.
> In order to filter these out, you use a "suppressions file" for
> valgrind. The manual has a
> good section on this and it should not be hard to wipre out most of
> them. Satish designed
> one for our unit tests.
> Matt
> Anyone have any suggestions on how to debug this tricky situation?
> Any suggestions
> would be greatly appreciated.
> Randy
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
