How to set the ksp true residual tolerance on command line
Ryan Yan
vyan2000 at gmail.com
Tue Jul 28 21:18:22 CDT 2009
Barry, thank you very much for the suggestion and the clarification.
Yan
PS: It should be -ksp_right_pc, instead of -ksp_pc_right:
-ksp_monitor_draw_true_residual: Monitor graphically true residual norm
(KSPMonitorSet)
-ksp_monitor_range_draw: Monitor graphically preconditioned residual norm
(KSPMonitorSet)
Pick at most one of -------------
-ksp_left_pc: Use left preconditioning (KSPSetPreconditionerSide)
-ksp_right_pc: Use right preconditioning (KSPSetPreconditionerSide)
-ksp_symmetric_pc: Use symmetric (factorized) preconditioning
-ksp_compute_singularvalues: Compute singular values of preconditioned
operator (KSPSetComputeSingularValues)
-ksp_compute_eigenvalues: Compute eigenvalues of preconditioned operator
On Tue, Jul 28, 2009 at 9:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> This depends on the Krylov solver and if you are using left or right
> preconditioning. With right preconditioning it always uses the true
> residual norm.
> So you can do -ksp_type gmres -ksp_pc_right
> Some methods we do not have implemented for right preconditioning, like CG,
> in that case you can use -ksp_type cg -ksp_norm_type unpreconditioned
> For CG many people prefer the energy norm which you can access with
> -ksp_norm_type natural
> -ksp_view should always show which it is using
> Barry
> On Jul 28, 2009, at 8:15 PM, Ryan Yan wrote:
> Hi all,
>> Is there any way to set a true residual tolerance on command line.
>> -ksp_atol is for preconditioned residual norm only.
>> Thanks,
>> Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090728/558c6eac/attachment.htm>
