Solver problem
    Tim Kroeger
    tim.kroeger at cevis.uni-bremen.de
    Tue Jul 28 08:42:20 CDT 2009
Dear Andreas,
On Tue, 28 Jul 2009, Andreas Grassl wrote:
> Tim Kroeger schrieb:
>> Would you recommend to try MUMPS as well?  (I.e., will MUMPS have a
>> change to be faster than ILU?)
> I would highly recommend to give it a try.
I can't get it running.  )-:
I used the chance and updated to petsc-3.0.0-p7.  I configured with
MUMPS and compiled succesfully.  I run my application with
-pc_factor_mat_solver_package mumps -pc_type lu, and then it crashes
with the following message:
symbol lookup error: /home/tkroeger/archives/petsc-3.0.0-p7/linux-gnu/lib/libpetscmat.so: undefined symbol: _gfortran_allocate_array
Otherwise, petsc-3.0.0-p7 works fine; that is, if I don't use the
above options, it doesn't crash.
What did I do wrong?
Best Regards,
Tim
Dr. Tim Kroeger
tim.kroeger at mevis.fraunhofer.de            Phone +49-421-218-7710
tim.kroeger at cevis.uni-bremen.de            Fax   +49-421-218-4236
Fraunhofer MEVIS, Institute for Medical Image Computing
Universitaetsallee 29, 28359 Bremen, Germany
