Solver problem
Tim Kroeger
tim.kroeger at cevis.uni-bremen.de
Tue Jul 28 01:22:49 CDT 2009
Dear Barry,
On Mon, 27 Jul 2009, Barry Smith wrote:
> On Jul 27, 2009, at 4:35 AM, Tim Kroeger wrote:
>> In my application, there is a linear system to be solved in every time
>> step. Steps 0 and 1 work well, but in step 2 PETSc fails to converge. I
>> suspected that the system might be unsolvable in that step and checked that
>> by writing matrix and the right hand side to files and loading them into
>> "octave". Surprisingly, "octave" does find a solution to the system
>> without any problems.
> Octave is using a direct solver. Did you try PETSc's direct solver using
> -pc_type lu?
Good idea! It works, and I'm actually surprised that it does. I did
try ILU(3) before (i.e., -pc_type ilu -pc_factor_levels 3), which took
forever to compute. Hence I thought that full LU would take even
longer, but this turned out to be not true; LU is accetible in
performance and solves the problem for that test case. I'll see how
it will behave on a larger-scale problem and on multiple cores.
Would you recommend to try MUMPS as well? (I.e., will MUMPS have a
change to be faster than ILU?)
Best Regards,
Tim
Dr. Tim Kroeger
tim.kroeger at mevis.fraunhofer.de Phone +49-421-218-7710
tim.kroeger at cevis.uni-bremen.de Fax +49-421-218-4236
Fraunhofer MEVIS, Institute for Medical Image Computing
Universitaetsallee 29, 28359 Bremen, Germany
